HID level adjustment
Old Jan 8, 2006 | 11:55 AM
ppith's Avatar
ppith
Smile HID level adjustment
I don't have any before/after pictures, but I recently had a mechanic pal adjust my levels 1.5 inches higher on both the driver and passenger side. I can definitely see further at night when there are no streetlights. At first, it seemed a little dimmer close to the car. But then I realized that was because less light is being directed onto the ground in front of the headlamps.
Now if there is something in the street, I think I will be able to see it and avoid it instead of seeing it (at the last minute) and then potentially hitting it.
Old Jan 9, 2006 | 10:03 AM
350TX's Avatar
350TX
Yeah I adjusted mine too after realizing that visibility was comparatively worse than regular halogens when driving on roads with no streets lights. Fortunately enough I have yet to encounter anything in road where it was too late to react. Is there a TSB on this issue?
Old Jan 9, 2006 | 02:37 PM
m0nkie's Avatar
m0nkie
you can do that yourself with a long philips end screw driver.. but i havent had any luck finding one thats 12 inches long
Old Jan 9, 2006 | 06:36 PM
ppith's Avatar
ppith
At least where I live, the Nissan mechanics are pretty cool and friendly. I am sure if you could meet one they could do the adjustment for you with their tool. Or you could just hit up Lowe's/Home Depot and do it yourself. I am also surprised there is no TSB for this issue because stock HIDs seem really keen on lighting up the ground directly in front of the car instead of further down the horizon.
Old Jan 9, 2006 | 07:37 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Harbor Freight sells the long screw drivers as do some of the $0.99 stores around here. I've got mine too high and the high beams are worthless - you can't tell if they're on or off.
Gotta fix that tonight.
Old Jan 10, 2006 | 11:40 AM
Jun's Avatar
Jun
Home Depot - $8.99 for a 18" one
Old Jan 10, 2006 | 12:13 PM
m0nkie's Avatar
m0nkie
man im prob not doing it right... iv went to homedepot and sears in LA.. several and none of them had anything longer than 10" Pepboys didnt carry any either..
Pleask
Dec 21, 2021 03:17 PM
sales@czp
Sep 23, 2019 03:30 PM
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
