View Poll Results: running hood pins on CF hoods?
yes, i have em.
16
26.23%
no, none for me.
45
73.77%
Voters: 61. You may not vote on this poll
how many of you with cf hoods are using.....
hood pins, locks etc. I just installed my seibon oem hood and don't really want to run ugly pins on my car... just wondering on the percentage of you guys with pins. if you're replying to the thread, post your brand of hood.
Just put Seibon VT hood on. I will test drive it before deciding if it needs pins. I don't like the look with the pins in, but IF it is necessary for safety I have found a really nice Italian billet aluminum set that would be awesome as an alternative to the standard types. Not cheap though.....
it's ugly vs safety.
which one would you rather have?
i have Fiberimages OEM CF hood with Sparco Al. Hood pins..
but check these out!!
SFC AeroCatch hood pins. they are new.
http://www.aerocatch.com/
$86 Non locking
$97 locking,
Coast Fabrication, Inc.
Ph: 714/842-2603 Fax: 714/847-1824 e-mail: info@coastfab.com
16761 Burke Lane Huntington Beach, CA 92647
BTW. these are the same as TopSecret's hood pins that they are selling for $100 more.
$86 Non locking
$97 locking,
Seibon VT and no hood pins. Been testing out at 120mph some time. It's my daily drive. No problem so far. If you have the hood installed correctly then you shouldn't worry about this.
Seibon VS .. with pins.
Ugly or not.. they are an extra layer of protection.
Consider this:
Your CF hood's latch is attached to the hood with resin. Its not bolted on.. or welded on. Resin is hard, and strong.. but its not going to hold with the same force that a metal bolt, or weld would. I firmly believe that over time and repeated stress, the resin sill not retain its original holding properties.
Hood pins are your friends
Consider this:
.. but its not going to hold with the same force that a metal bolt, or weld would. ..
+10000000
well i know stillen...and maybe kaminari... weigh the same or more than stock... so im not worried about it popping up... however if i had a nice light weight dry carbon hood or something I would look into pins.
Consider this:
Consider this:
if its a hood that has the latch attached with resin i would definatly use pins...
$86 Non locking
$97 locking,
$86 Non locking
$97 locking,
Originally Posted by NiSmO D1X
hey chebosto, from the look sof the aerocatch, do the inst6all require you to cut a portion of the hood to install that particular latch?
the AeroCatch pins have a template in which you cut out to accomodate the latching system.. (templates included) i'm sure once you DO cut it, you can't go back to a conventional (cotter pin) hood pin setup
gringott--- post picts after the install.
