headlight question.
Old Jan 28, 2006 | 04:39 PM
LvntheZ's Avatar
LvntheZ
Default headlight question.
ok this is the situation i have a base model Z(non HID) and someone offered me to trade their track model 03 z's headlight (HID)due to some stuff. i was just wondering if it would be just a straight headlight swap? will the housing and everything work on my base model or will it not fit?.thanks
Old Jan 28, 2006 | 05:03 PM
LvntheZ's Avatar
LvntheZ
Originally Posted by mc350z
no the harness plugs are different. the HID use a 6 pin and the plug on your car is a 4. you can convert them but its not a straight plug and play. do a search and there is a thread on here that shows you how to do it
how about for his set up will mine plug up to his? so then i can do the mod to mine?
Old Jan 28, 2006 | 05:14 PM
LvntheZ's Avatar
LvntheZ
well thanks anyways man can you send me the link to see how to do the modd.
hmmm. will a non HID plug into a model with HID. i dont know the answer to that. i would guess yes but i dont have any info to back that up. the reason i know about the different harnesses is because i sold my HIDs to someone with out HID.
maybe someone else can verify if non HIDS will plug into a hid plug. i guess it might just use 4 of the 6 pins in the plug but once again im not sure
Old Jan 28, 2006 | 07:10 PM
showstoppertk's Avatar
showstoppertk
it will not work. the prongs/connections are different. you will either need to cut off the pins and try to figure out which wires are for what and then souder them together, however you may still have problems as the non-hid wiring may not be rated to handle the higher intial power of the HID's. in other words you may end up lighting you car on fire. if you go this way I would suggest having a reputable automotive electritian hook this up for you. also don't forget to upgrade your fuses. I would actually suggest just buying an OEM HID Kit from Jun, he's a member on this board and well known for his kit. otherwise good luck.
Old Jan 28, 2006 | 07:32 PM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
his buddy is probably turning in a lease or trading car so he's hooking his partner up? yeah i know whats up, lol
Old Jan 29, 2006 | 03:03 PM
LvntheZ's Avatar
LvntheZ
hahahaha true get ur moneys worth.........thats what friends are for!
Old Jan 29, 2006 | 03:12 PM
JPsZ's Avatar
JPsZ
don't try to front like your car came with hids, just stick with what you got... A BASE MODEL. j/k hey you got aim fool? hit me up and what are you day offs?
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
Kilroy.Bukowski
Sep 26, 2015 11:24 AM
_koubie_
Sep 20, 2015 06:34 PM
