OEM Spoiler installation just using double sided tape
Old Jan 30, 2006 | 07:19 PM
mikerz's Avatar
mikerz
Default OEM Spoiler installation just using double sided tape
I have an OEM Spoiler and would want to install on my car.
But don't want to drill any holes, I was thinking of cutting the bolt and just use double sided tape.
Any advise on this if this would hold up and would be a great idea.?
Old Jan 30, 2006 | 09:06 PM
Strife350z's Avatar
Strife350z
do a search
it's not a problem... lots have done it before, including me... just make sure you use body-kit grade double-sided tape. Proform or 3m; they're very sticky... handles over 5lbs per square inch
Old Jan 31, 2006 | 07:16 AM
H.C.I.C.'s Avatar
H.C.I.C.
Can you get this tape at home depot or does it have to be body shop?
I'm planning to do an install this weekend for a friend. Anyone know or have a picture of how far the stock spoiler sits from the back?
Old Jan 31, 2006 | 08:11 AM
Strife350z's Avatar
Strife350z
AFAIK, a body shop or a speciality shop dealing with autobody repair (i got mine from the latter).
Installation is painless.
1) Saw off the mounting bolts, then line the inside edges of the spoiler with tape; make sure you only peel the side that needs to adhere to the spoiler.
2) Position the spoiler over the trunk. You'll find that there's only about an inch or so on the entire trunk where the curve of the spoiler matches the curve of the hatch. It's an OEM part afterall.
3) If your'e nitpicky, find a track model Z with the OEM spoiler installed and measure the distances
4) When you've finalized the mounting point, use masking tape to mark the edges on your hatch
5) With one hand holding the spoiler in place, begin peeling the adhesive backing. Keep gentle pressure on the spoiler with your other hand so it doesn't shift position.
6) Once all the backing has been peeled off and the spoiler is now attached to your trunk, apply light pressure on it for about 10-15 mins. You might want to use a paper-weight. Just make sure to pad it.
Done.
Old Jan 31, 2006 | 08:12 AM
Strife350z's Avatar
Strife350z
forgot to mention... prep your hatch first if there's a lot of wax on it with dawn and a clay-bar
Old Jan 31, 2006 | 11:06 AM
H.C.I.C.'s Avatar
H.C.I.C.
Thanks Strife, Saved me some time from going to home depot.
Old Mar 15, 2012 | 11:26 PM
ALO8's Avatar
ALO8
anyone know what 3m tape thickness or item number would be good for oem spoiler?
Old Mar 16, 2012 | 05:25 AM
Angel55's Avatar
Angel55
If you are thinking of installing the spoiler with just the double sided tape you might have to cut the bolts under the spoiler. I was at the dealer trying to get an oil change, and i ask the mechanic to cut the bolts for me. I ended up giving him five bucks.
Old Apr 3, 2012 | 09:39 AM
ALO8's Avatar
ALO8
ALO8's Avatar
ALO8
is there a specific item number from 3m that would be good for oem spoiler?
Old Apr 4, 2012 | 02:21 PM
ALO8's Avatar
ALO8
i take it they're all the same as long as its 3m?
Old Apr 4, 2012 | 03:50 PM
Diabolik350's Avatar
Diabolik350
Dude, just google 3M automotive tape.
Old Apr 4, 2012 | 03:54 PM
Driven1's Avatar
Driven1
Professional
Since Im in a good mood.
Here you go. You can actually get it at most auto stores like Advance and AutoZone.
http://solutions.3m.com/wps/portal/3...beSQHC842H7Fgl
Old Apr 4, 2012 | 04:16 PM
ALO8's Avatar
ALO8
lol, they have so many different kinds, google is not my friend
Old Apr 4, 2012 | 04:18 PM
ALO8's Avatar
ALO8
thnx. ima go with either pressure sensitive or heat sensitive as this diagram suggests:
http://solutions.3m.com/wps/portal/3...-Applications/
Old Apr 4, 2012 | 04:20 PM
Driven1's Avatar
Driven1
Professional
The key is prepping the surface.
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
kyin
Oct 15, 2015 05:54 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
Suffolk350z
Sep 13, 2015 02:43 PM
