Install of Aerosync front bumper.
Old Feb 5, 2006 | 10:19 PM
joust75's Avatar
joust75
Default Install of Aerosync front bumper.
Hi guys. I am ordering my Aerosync front bumper tomorrow. I plan on having a friend paint it. I want to avoid unnecessary costs so I need to know how hard it is to remove the front bumper and install the aerosync one.
Has anyone had experience with installing it? How long does it take? Any drilling necessary or does it bolt right on?
Thanks!
Old Feb 6, 2006 | 10:39 AM
davidf's Avatar
davidf
I have also ordered this bumper, I've had my stock one off before, it's not very hard.
Old Mar 9, 2006 | 05:59 AM
Tortuga's Avatar
Tortuga
Bump. Anyone install Aerosync bumper? How easy? Use EOM mounting points? Any custom fabrication needed? Is it predrilled? thanks
Old Mar 9, 2006 | 07:42 PM
risin's Avatar
risin
I would also like to know.
I have read that the bottom of the bumper has no drill holes. How does the lower plastic plate connect to the bumper, since the nismo style bumper is lower than the oem bumper. Do i need brackets to hold the bumper and plastic plate together?
Old Mar 9, 2006 | 08:00 PM
kamikaZ's Avatar
kamikaZ
3FIFTYZ
good question..
Old Mar 9, 2006 | 08:04 PM
JPsZ's Avatar
JPsZ
i just set the bumper on, and using a marker, marked where I needed to drill small holes at on the bumper.
Old Mar 10, 2006 | 03:21 PM
joust75's Avatar
joust75
I have the bumper. it is a nice quality piece. No money now to get it painted, but when I do I will have it proffesionally painted and will do the install myself to save $$.
Here is some removal info I saved in a text file forgot who I lifted it from but I believe it was LAoSiFu. Props.
REMOVING THE FRONT BUMPER
1. Open up your hood and remove 6 clips on top of your bumper with a flat head screwdriver.
2. Under your car has (8)10mm screws that need to be remove with a 10mm socket wrench
3. Where you fender and bumper touch, on each side has a 10mm screws. Remove them.
4. From inside, under the headlight should have (2)10mm screws. Remove them
5. The front bumper should come right off, if not please double check for any left over screws that may have not come off.
Old Mar 10, 2006 | 05:08 PM
davidf's Avatar
davidf
Once I installed mine I lifted the car and put the lower plastic on, marked holes on the lower bumper where the plastic meets the bumper and bolted the plastic to the bumper, simple and secure. That took a total of about 15 minutes and you will reuse the bolts and nuts off your original lower bumper.
Old Mar 10, 2006 | 08:39 PM
Zilvia's Avatar
Zilvia
yeah make sure you get the fronts up on jacks so you can take off the front wheels, makes getting to the 3 plugs under each fender a hell of a lot easier to get to
Old Mar 11, 2006 | 10:16 AM
davidf's Avatar
davidf
Damn I forgot to say that, Thanks.
Old Mar 11, 2006 | 05:07 PM
jckolnturn's Avatar
jckolnturn
Does the the diffuser panels under the car bolt back up to the new bumper?
Old Mar 11, 2006 | 05:34 PM
BobbyRitz's Avatar
BobbyRitz
There is no need to take the front wheels off. Just turn the wheel so it's easier to access the inner well liner.
Old Mar 12, 2006 | 10:36 PM
risin's Avatar
risin
I just ordered the bumper from kurumaz.com and was told that the bumper comes with simple spacers and bolts.
Old Mar 13, 2006 | 04:50 PM
davidf's Avatar
davidf
Thats wierd they did'nt include any spacers or bolts with mine but I did'nt need em.
Old Mar 14, 2006 | 12:46 PM
jckolnturn's Avatar
jckolnturn
Can anyone tell me if the diffuser panel bolts to the Aerosync bumper?
Old Mar 19, 2006 | 01:26 PM
sluggoZ's Avatar
sluggoZ
good point.
Old Mar 19, 2006 | 01:30 PM
FirstZ's Avatar
FirstZ
most of them do
Old Mar 21, 2006 | 12:05 PM
jckolnturn's Avatar
jckolnturn
most of what do?
Old Mar 21, 2006 | 12:24 PM
mchong75's Avatar
mchong75
Hmmmmm, after 1 month of original post...no pics yet?
Or are you still trying to get the stock bumper off? LOL
Old Mar 21, 2006 | 02:11 PM
joust75's Avatar
joust75
I have a newly aqquired mortgage payment. No money for getting it painted yet. . Ill let you know.....
