New Ideas for exterior styling mods.
Old Feb 10, 2006 | 08:10 AM
Z33_SPL's Avatar
Z33_SPL
I'd like to see 20mm wider front fenders and 50mm wider rear overfenders. Something we could rivet on and replace if we smash it up. I wish Ridox would make aero for the 350Z just like their Supra.
Note the half FRP half carbon fiber front bumper and sideskirts.
Old Feb 10, 2006 | 10:04 AM
ghost11's Avatar
ghost11
Originally Posted by ghost11
a front splitter designed for the z without just a plain curved edge (not carbon)
do you guys not think this would be cool?
Old Feb 10, 2006 | 10:41 AM
mdracer76's Avatar
mdracer76
CF Rear Defuser... thats FUNCTIONAL
Old Feb 10, 2006 | 11:04 AM
Chebosto's Avatar
Chebosto
functionality wise, you want the longest piece of (material) infront of the nose, flat or curved, to push the nose down.
you can use balsa wood and wrap it with fiberglass and paint it black for the same affect as the APR splitter.
once you start throwing curves into the design, you have to watch out. adverse air flow affects at the cost of looking pretty.
rear diffuser is idea. but exhaust is the variable
what might be more beneficial is a plug to fill the hole where the muffler used to be-..
Zillinois is on the right track. but the triangluar piece in the front, presumably mounting near the rear diff, still allows for alot of air to get in ...
Old Feb 10, 2006 | 02:27 PM
zillinois's Avatar
zillinois
Originally Posted by Chebosto
1/4" or 1/8" thick?
aluminum?
Its .063 with a kynar finish so its specs out a little less than an 1/8" and yes its aluminum.
Old Feb 10, 2006 | 02:39 PM
zillinois's Avatar
zillinois
The stock muffler location is almost completely plugged with that piece and it follows along side the pipes of at least one type of aftermarket exhaust. That's about as good as I could come up with given the constraints. Any suggestions would be appreciated. I wanted to make it pretty simple. Carbon is nice but its much more difficult to work with than aluminum and not any stronger.
As for the triangle part, It bolts to the lower two bolts of the pumpkin and fills the gap between the exhaust pipes. So thats pretty plugged. I've got two rather large vortex generators at the cliff of the radius up and they are at a relatively aggressive angle of attack so they should generate better flow than what's there anyway. I put a fence in between them so they wouldn't cancel each other out. I'm trying to get a test fitter this weekend so I can make any last minute changes.
Old Feb 10, 2006 | 04:29 PM
nickgundara's Avatar
nickgundara
Better options for vented hoods would be nice.
Old Feb 10, 2006 | 04:36 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
+1. Also, they should be able to allow for tall plenums & aftermarket strut bars. I've found a lot of them rub. It would also be good that they make the latch & hinge area stronger (aluminum) so that you won't have to rely on hood pins. Perhaps an aluminum frame?
Old Feb 10, 2006 | 07:11 PM
Randall Patters's Avatar
Randall Patters
Lips for 06 bumpers, more wing ideas
Old Feb 16, 2006 | 09:34 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
JGTC Style Headlights!
Old Feb 17, 2006 | 12:42 AM
k3silk's Avatar
k3silk
need a damn lip for the 06 come on.
07ZEKE
Aug 23, 2021 09:15 PM
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Alexreyes
Sep 30, 2015 11:30 PM
Tochigi_236
Sep 27, 2015 03:40 PM
