Custom Rear Diffuser (first prototype)
Old Mar 2, 2006 | 10:33 AM
Auto RnD's Avatar
Auto RnD
well... you could always use a diffuser to improve aerodynamics of the stock z...
Hopefully someone will make a similarly funtional piece
Old Mar 2, 2006 | 10:39 AM
SinCity350Z's Avatar
SinCity350Z
Track Whore
The Z stock actually has a really really low drag coeficient, especially the track model. Nissan put a lot of research into it and thats why the stock muffler sits the way it does. Esentially the stock muffler is your diffuser with the way it is shaped and positioned. If there were any slight benifit on using this with the stock muffler, it would be hard to justify the cost, unless you were going for pure looks.
Old Mar 2, 2006 | 11:55 AM
Hybrid90's Avatar
Hybrid90
JDMZ33 - did you make that yourself or did you order it from somewhere? If so, where and how much?
+1000 on installed pics
Old Mar 2, 2006 | 12:26 PM
leemik's Avatar
leemik
If you are putting these custom diffusers on, you should also consider buying the two OEM Track diffusers.. They go into the back just behind the wheel well and as far as I can tell it covers the opening that's there on non-track model Z's to further reduce drag..
--mike
Old Mar 2, 2006 | 12:27 PM
SinCity350Z
Track Whore
--mike
Yep, these are the reason that the track model Zs have slightly less drag than other models.
Old Mar 2, 2006 | 01:02 PM
eat rice z33's Avatar
eat rice z33
correct! i orderd these couple dqays ago! I am not finishing modifying my body kit for perfect air flow. im cutting out the center and making a CF air plate with vortex generators instead of the kits two stubby fiberpieces. heres a pics of what it looks like now
Old Mar 2, 2006 | 05:52 PM
ss350's Avatar
ss350
subscribing
Old Mar 6, 2006 | 08:43 AM
UsafaRice's Avatar
UsafaRice
There would certainly be a market for these if you were to make em and sell em. Or powdercoat them.
Plenty of people have exhaust that leave that open space. My question is whether this would work with the stock exhaust, cause I think my (as well as some other folks') Amuse exhaust matches that size.
Old Mar 8, 2006 | 12:39 PM
MurphysZ's Avatar
MurphysZ
subscribing
Old Mar 8, 2006 | 01:20 PM
Zilvia's Avatar
Zilvia
.....this is getting quite good................btw how do you subscribe to stuff( i feel like a total noob right now)
Old Mar 8, 2006 | 03:32 PM
EnthuZ's Avatar
EnthuZ
You just did! A reply will get you hooked up, but check you're settings. You need to check the "e-mail notification" (I think that is what it's called) box.
Old Mar 8, 2006 | 03:37 PM
SinCity350Z
Track Whore
I am starting to do the test fit of this diffuser right now! I will keep you posted on how it goes.
Old Mar 9, 2006 | 05:35 AM
Redfoot's Avatar
Redfoot
Rebuilding his race car and making Z parts, How does he do it?
Old Mar 9, 2006 | 09:42 AM
Goofy1477's Avatar
Goofy1477
subscribing
Old Mar 9, 2006 | 09:45 AM
nissansource's Avatar
nissansource
Originally Posted by spdu4ia
good design... but be carefull on mounting to the rear bumper (at least the stock one) this is a picture of the one i made of carbon and the force it created tore the lower bumper supports and the bumper started flapping. mabey think of a way to reinforce it somehow. just FYI
Im digging both!
Old Mar 9, 2006 | 10:10 AM
SinCity350Z
Track Whore
Well I have to find a way to secure the rear of the diffuser as my bumper is warped and leaves a gap when I mount it where Geoff (Zillinois) intended it to mount.
Old Mar 9, 2006 | 10:25 AM
Chebosto's Avatar
Chebosto
time to head to Home Depot Racing Department....
i still dont know where to attach my blank to the rear diff area....
Old Mar 9, 2006 | 10:35 AM
  #38
buzzardmountain's Avatar
buzzardmountain
Originally Posted by JDMZ33
Here you go...
Any updates Jay?
Old Mar 9, 2006 | 10:40 AM
  #39
KaiserSoze's Avatar
KaiserSoze
A better way to attach it is to use the actual metal rear bumper or something along that line. You'd just have to figure out where you want to attach it, then fab some mounting brackets using some aluminum strips. That way you don't have to worry about f'ing up your rear bumper cover.
Old Mar 9, 2006 | 11:11 AM
  #40
UsafaRice's Avatar
UsafaRice
Oh, I just thought of some other stuff we need. A front pan extension to about the transmission area and a flat bottom section for the middle of the car up to the differential for the full length effect. Of course, it will need NACA ducts or the like for transmission and differential cooling, as well as ducts for the read brakes.
