anyone removed there Factory SEATs???pictures??
Old Mar 22, 2006 | 12:28 PM
ZZ33bOI's Avatar
ZZ33bOI
Default anyone removed there Factory SEATs???pictures??
I am going to remove my seats pretty soon..just want to kno what am i gettin into..Is it only 4 bolts??? any pictures will be perfect..step by step instructions will be even better..
THANKS!
Old Mar 22, 2006 | 12:39 PM
cessna's Avatar
cessna
On the G....
4 bolts, and the power seat/heat must be disconected via a little plastic clip.... (If I remember correctly)
I take mine out twice a year to detail her completly.
Old Mar 22, 2006 | 12:41 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
4 bolts and maybe an airbag harness if you have it. I swap seats on the passenger side atleast once a month
Old Mar 22, 2006 | 12:44 PM
showstoppertk's Avatar
showstoppertk
rick-you diconnect the battery prior to unplugging the airbag harness right?
Old Mar 22, 2006 | 12:56 PM
ZZ33bOI's Avatar
ZZ33bOI
thanks...yeah i have AIrbag/heated and PWR...im sure its just a lil clip that connects it..good question do we need to take out the battery? i dont want the air bag to pop and knock me out..hahah
Old Mar 22, 2006 | 02:12 PM
zedated's Avatar
zedated
Why would you need to disconnect the battery before the airbag harness? If the car is OFF, there's no power going to the airbag, right???
Old Mar 22, 2006 | 02:25 PM
Vamos_Rafael's Avatar
Vamos_Rafael
because if u turned off the car and the computer senese there is a passenger inside then u get nailed... the air bag still deployes to save u...?
maybe thats why...
because u have to disc the battery terminal for steering wheel removal to prevent airbag deployment...
Old Mar 22, 2006 | 02:48 PM
ZZ33bOI's Avatar
ZZ33bOI
^ thats true...so on the safe side i should disconnect it anyways..so i wont get knocked out by XXXX amount of PSI and i kno its A LOT~! I MEAN A LOT! it will knock u out silly...
Old Mar 22, 2006 | 02:50 PM
Vamos_Rafael
i watched the show on car safety on the national geographics channel...
it shoots out at over 200mph and deployes in just a couple milliseconds!
an airbag is nothing to messs with...
getting shot by an airbag point blank might kill u
Old Mar 22, 2006 | 03:41 PM
showstoppertk
very, very true. although I think I'd laugh if I someone get hit with one.
http://video.google.com/videoplay?do...16059&q=airbag
Old Mar 22, 2006 | 03:58 PM
jakesford's Avatar
jakesford
now I know this is true on some cars but isn't there a back up, such as a capacitor to provide power for the airbags in case power is lost before deploying...?
Old Mar 22, 2006 | 04:28 PM
bjr's Avatar
bjr
get ahold of the service manual or have someone look it up for you to double check - but YES at the very least disconnect the battery for about 10 minutes before touching anything to do with an airbag connector. Also make sure you have no static electricity buildup on you. In case of an accident involving battery cables getting smashed all airbags must have a backup charge of electricity to deploy them as a backup. Usually capacitors in the airbag computer or something like that. And the bags are serious business. I've seen propulsion canisters being made and its about a 3/4" to 1" diameter shell full of blue powder very much like gunpowder. It has to be compressed in a canister to explode with the charge. There still can be flash fires in the plant though from being careless Not the safest factory to be in! It's like having a loaded weapon pointed at your head if you are grasping the seat and pulling it out when it goes off.
Be careful, this is exactly why I did not take my seats out just to put my amplifiers in, but may consider taking out the carpet this spring to add some sound deadening. Make sure you do it right.
Old Mar 22, 2006 | 04:35 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Never did and the bags never deployed
Old Mar 22, 2006 | 04:54 PM
hndumafia's Avatar
hndumafia
just make sure not to turn the car on while the seat is out, or the airbag light will go on and will have to be reset by the dealer (or maybe there is a way to reset it yourself i dont know).
Old Mar 22, 2006 | 05:01 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Very true! Once the sensor is tripped, you have to go to the dealer to have it reset. Mine I don't care about since I don't have any airbags in place
Old Mar 22, 2006 | 07:48 PM
ZZ33bOI's Avatar
ZZ33bOI
THANKS you guys for all the tips..i'll make sure everything is properly done! when i swap my seats out...
Depravity
Oct 1, 2015 04:49 PM
