Bolts holding hood stripped...
Old Apr 3, 2006 | 07:07 AM
dirtroad's Avatar
dirtroad
Default Bolts holding hood stripped...
Basically I need to replace two of the four bolts holding my hood to the hinges on either side. It looks like the only way to get these out is by cutting them out and welding new ones in place. Anyone ran across a similar problem?
Old Apr 3, 2006 | 07:37 AM
HarvesterUT's Avatar
HarvesterUT
you might be able to just buy a pair of OEM hood brackets...thats my best guess
Old Apr 3, 2006 | 07:56 AM
Chebosto's Avatar
Chebosto
i thought the bolts were on the hood side- not the bracket/hinge portions.
how did u strip them?
Old Apr 3, 2006 | 08:07 AM
dirtroad's Avatar
dirtroad
Chebosto's right - I had some 1/2" thick washers on there to act as spacers to get more air flow under the hood. Guess those bolts are pretty soft cause the threads got mangled.
Old Apr 3, 2006 | 09:00 AM
HarvesterUT
so you took the spacers off and now the bolt wont thread again, right? man that stinks
Old Apr 3, 2006 | 09:04 AM
Chebosto's Avatar
Chebosto
hm.. you used something like this?
you could just run a die across the threads to try re-do the threads?
Old Apr 3, 2006 | 09:27 AM
dirtroad's Avatar
dirtroad
i'll probably try that - haven't done it before - is that some sort of kit from the hardware store?
Old Apr 3, 2006 | 09:30 AM
ZlleH's Avatar
ZlleH
You might also want to torch the bolts to get them to come off easier.
Old Apr 3, 2006 | 09:35 AM
dirtroad's Avatar
dirtroad
yeah, looks like i'm calling a welder - replace all 4 bolts with steel ones.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
