Distribution Block Question
Old Apr 10, 2006 | 12:10 PM
z350boy's Avatar
z350boy
Default Distribution Block Question
What is a distribution block and how it to be used??
Can I use it to run stereo and car alarm wiring??
Old Apr 10, 2006 | 12:23 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
It allows you to run one single wire from the battery or from a ground point on the frame to a central point in the rear of the car or where ever you would like to.
From the distrobution block you can power or ground multiple amps without running multiple wires to the battery.
Old Apr 11, 2006 | 12:20 PM
z350boy's Avatar
z350boy
Any suggestions on which kind I would need??? I will be running an ARC amp w/ Dynaudio 6.5's & Image Dynamics 10" sub; HU TBD. Where should I run it from?? Really appreciate the help!!
Old Apr 12, 2006 | 12:39 PM
xtrememan315's Avatar
xtrememan315
How many amps u running? If only one amp u don't need one but if you have more than one then you'll need two distribution blocks.
For instance I have 2 amps: JL 500/1 and 300/4 and I have a 2 Gauge wire from battery into factory sub location (amps mounted there) and then that wire gets split down into 2 - 4 Gauge wires (one for each amp - power) and the same goes for the ground wire. One wire ran to Distribution block then split into 2 wires (one for each amp)
Hope that helps, search Yahoo! too they have alot of helpful tutorials on Stereo equip!
sherm
Apr 11, 2020 05:21 PM
issyz
Jul 2, 2017 03:04 PM
