Glow Gauges
Old Apr 10, 2006 | 05:00 PM
UBERMENSCH's Avatar
UBERMENSCH
Default Glow Gauges
Anyone know who still manufactures glow gauges. Given the way cars are made now adays it seems like they are a dieing breed. I am having trouble tracking some down. They would go into a 1998 nissan maxima.
Old Apr 10, 2006 | 05:20 PM
DIGItonium's Avatar
DIGItonium
http://www.procarparts.com/store-det...=onlinestoreDB
Is this correct?
Old Apr 10, 2006 | 06:04 PM
UBERMENSCH's Avatar
UBERMENSCH
thanks, I was wondering do you know if they are hard to install I plan on doing the job myself.
Old Apr 11, 2006 | 10:48 AM
DIGItonium's Avatar
DIGItonium
Sliding them through the needle is scary at first, but it is not bad if you can "flex" the gauge faces such that the opening can easily fit over the needle.
The tricky part is probably trying to get the faces to lay flush with the cluster so the needle does not get caught on it. Some use scotch tape or double sided tape, but it takes up too much room. I prefer some sort of silicone adhesive or spray that is not permanent (like super glue).
If your gauge cluster has 1-2 bulbs above it that lights up the front of the faces, you can remove them so you can see the faces better. It is harmeless to remove backlighting bulbs if not needed, but some will keep the needles lit.
Tap into IGN power and the other to chassis ground (any ground point that is convenient).
The reason why I would steer clear of Indiglo faces is because of it's limited life. Over time they start to get dim or die out - face or inverter dies.
I prefer LED work. It is not bad at all if you know how to use the soldering iron. If your gauge cluster has white labels during the day, and lights up "white" at night then it is possible to use LED lighting. You need some high powered Luxeon side emitters, 1W resistors, soldering tool, and a multimeter. There's no need to disassemble the entire assembly or touch the needles! Just pull out the stock backlight bulb, determine the polarity of the contacts, and solder the resistor and Luxeon. Make sure you don't over heat the thin circuit membrane and plastic.
Cost estimate: $3 for each Luxeon (the Z32 took 4, some cards take 6), and1W 100ohm resistors from Radio Shack for < $10.
Here's a pix from my dad's Z32 (bad picture):
http://members.***.net/djtonium/imag...ies/led/00.jpg
Old Apr 12, 2006 | 10:21 AM
maxpowers's Avatar
maxpowers
I put indiglo gauges (from pro car parts) in my old 3 series and wouldn't recommend it. After a year they started to flicker, and becuase they are flexable, they were lifting away from the guage face in some places.
Old Apr 12, 2006 | 04:56 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Yeah, better to replace the whole system. Those overlay type of stuff is cheap and looks ricey IMO
Old Apr 12, 2006 | 05:55 PM
DIGItonium's Avatar
DIGItonium
Nah... it just involves removing the bulb and soldering in a side emitting Luxeon with a 100ohm 1W resistor. It'll suffice.
Old Apr 12, 2006 | 07:53 PM
UBERMENSCH's Avatar
UBERMENSCH
That's what I was afraid of, I think I will just leave it stock. Thanks for your input.
Old Apr 12, 2006 | 08:39 PM
DIGItonium's Avatar
DIGItonium
If the Maxima uses incandescent bulbs (194 wedge type) to light up the cluster versus LED for our Zs, then it's a 30min soldering job with Luxeons. I've done this mod with Civics, Integras, and of course, the Z32.
Old Apr 23, 2006 | 09:28 PM
UBERMENSCH's Avatar
UBERMENSCH
cool. ...I think I will stay stock though maybe go for another mod.
bcoffee20
Nov 19, 2015 06:39 PM
Calinismo350z
Sep 14, 2015 04:04 PM
