New Hood Dampers/Springs!
Old Jun 24, 2006 | 11:12 PM
Amiricanmade's Avatar
Amiricanmade
ok so no group buy? com'on WTF!
Old Jun 25, 2006 | 12:33 AM
Fairlady_z33's Avatar
Fairlady_z33
Yea any final words on this
Old Jun 25, 2006 | 07:01 PM
brigz's Avatar
brigz
Im interested
Old Jun 25, 2006 | 07:31 PM
New2350's Avatar
New2350
I have been waiting for a couple of month to see if this will work well with the Vortech. Good Luck Guys I am unsubscribing.
Old Jun 26, 2006 | 11:27 AM
HarvesterUT's Avatar
HarvesterUT
hey all! sorry for being MIA the past few weeks, but I was busy doing some Army training in Lousiana and then Virginia.
About the hood dampers, I assure you I am still tweaking them and should have an announcement within the week!
thanks for the interest!
Harv
Old Jun 26, 2006 | 11:31 AM
roncfpz's Avatar
roncfpz
Will they work on a fiberglass hood?
Old Jun 26, 2006 | 11:43 AM
HarvesterUT
assuming the hood has the same mounting brackets and they are in the same location as stock, then I assume they would work. however, i will caution that some people say to not use hood dampers with carbon-fiber hoods b/c they might not be strong enough to hold up since the pivot point is so low. i'm not sure how well fiberglass will hold up.
if you can open your hood (without the hood prop) and hold it open with your fingers on both sides down low, where you see the damper attatch to the base of the hood, without bending the hood or causing undue stress, i imagine it will be fine.
Old Jun 26, 2006 | 11:58 AM
minispider's Avatar
minispider
check this link out....
http://www.everything350z.net/c=7a9C...duct/BHD01-P24
Old Jun 26, 2006 | 12:30 PM
Nexx's Avatar
Nexx
Originally Posted by minispider
nice find!
Old Jun 26, 2006 | 12:47 PM
minispider's Avatar
minispider
Originally Posted by Nexx
nice find!
you guys owe me big time!!!!! ....so now...has anyone here have tinted the front JDM clear markers for an '06?...I need to know, please
Old Jun 26, 2006 | 02:34 PM
captj3's Avatar
captj3
The Tein have been around for a long time. Plus you can get them cheaper. The reason we are waiting, is with his dampers you don't have to cut anything under the hood to make them work.
Old Jun 26, 2006 | 04:43 PM
HarvesterUT
actually this is not true. the difference between mine and the TEIN is:
1) cheaper
2) easier install (i think anyways since no need to use a jack)
3) less cutting/melting in order to fit the damper
4) allows for complete plastic cover removal to get to Battery and Brake Fluid without the need to disassemble the hood dampers and brackets.
So, yes, you will need to cut a little bit of plastic to fit (or melt if you prefer), but not as much as the TEIN.
Old Jun 26, 2006 | 05:45 PM
captj3's Avatar
captj3
When I said cheaper I meant the tein. I stand corrected I thought you didn't have to cut anything for your dampers to fit. As for install I can't see to much of a difference. Sorry I was trying to help.
Old Jul 11, 2006 | 12:50 PM
HarvesterUT
quick update guys,
most kinks are ironed out and kit is complete. keep an eye on the Vendor GB forum where I will post all the info if you want to get in on the GB!!
Anthony
Old Jul 11, 2006 | 03:45 PM
HarvesterUT
Ok the GB is on! You can find it in the Vendors GB forum!
Clicky here to go to it!
BEBO'S ZEE
Jun 7, 2016 07:48 AM
EnjukuRacing
Misc.
Sep 23, 2015 07:27 AM
jdmctrek
Exterior
Sep 17, 2015 03:13 PM
Wu-Watt
East Canada
Sep 12, 2015 07:31 AM
