Rear Hatch Damper/Stays
Is anyone (besides me) running a rear wing having problems with the hatch staying up? I'm running the NISMO rear wing and can't seem to keep the frickin hatch open for more than a few seconds. I've clowned byself a few too many times. I'll be adjusting my subwoofer box or even taking things in and out of the trunk area when all of a sudden "KADUNK" the rear hatch drops and slams me on top of the head. It's quite embarrassing and kinda difficult lifting things with one hand while holding the hatch up with the other hand. Anbody got a recommended solution to my delima, or am I stuck with the stock stay/arms? Getting a concusion and need help
Yeah its a common problem and sadly the only real solution is to give in and buy nissan's rip-off nismo shocks. In their intelligence apparently they didnt anticipate that their own product would cause this problem. People will say that removing the weight in the hatch will help but after removing both the weight and wiper the trunk still has tendencies to fall.
Where are these weights I'm hearing about?
my dealer replaced mine under warranty (no spoiler) since it was falling down in the cold even without a spoiler,
now it's hard to close without putting weight on it, I'm sure it would support a spoiler without giving in...
Bottom line, you need to replace the stays...
Already tried going through a dealer they dont give a damn. As far as the weight some Z's have em some dont. No idea why. Basically remove the plastic covered under your hatch that lines around the window and covers the windshield wiper motor. Right in the dead center you will either see the weight or a gap where it would have been. Nevertheless this may not solve your problem. It's just stupid engineering on their part.
hi guys,
in approx. 4 weeks we have stronger rear hatch dampers. i have already installed the prototype. so i had the same problem with my strosek rear wing. now the hood goes automatic up afer you have lift the hood approx. 40cm. and they stay up! also by low tempratures that we have now in germany.
it will be a complete replacement kit with brackets. its not possible to remove the original brackets from the damper, so we make new brackets (black anodized).
tino
ps: at the moment we have finished the engine hood dampers.
tino
Originally Posted by CTD-Germany
hi guys,
tino
tino
Originally Posted by gunz914
Tino, when is the set going to be ready?
I havent fitted my rear wing yet, if i experience these same problem's when i do, ill get a pair of these for sure.
/Roger
According to Nissan, when installing the rear deck spoiler, new "upgraded" hatch shocks are to be purchased and installed. A total waste of money. I went this route and $340.00 later, still had a problem. I took the weight out of the hatch and voila! problem solved for almost a year now. I wish I had taken it out before I spent the extra cash!!!
Tino
We have a problem on the UK cars as well. Are you able to supply to us here.
We supply and fit a lot of spoilers and kits and it would be good to be able to offer this option.
Phil/PPS Motorsport
Phil/PPS Motorsport
seriously, carefully take the hatch plastic cover off, and remove the weight with 4 10mm bolts. it only weighs about a pound but it solved my hatch problems. with my hatch i had to hold down the trunk pop button twice everytime. then i removed the wiper and it popped up even better.
Done this but still drops.
