How to remove side skirts???
Old May 23, 2006 | 10:14 AM
eat rice z33's Avatar
eat rice z33
Default How to remove side skirts???
Can someone please help me remove my side skirts. I know there are two clips in the rear wheel arch. and some under clips but how do i remove the under clips and how to remove the clips in the door panel?
Old May 23, 2006 | 10:19 AM
B-Unit's Avatar
B-Unit
its held on by clips at the front and rear fenders. 10mm bolts on the underside of the skirt. and pop rivets between the skirt and frame.
Old May 23, 2006 | 10:54 AM
05-Z's Avatar
05-Z
^ Exactly....should take less than 5 minutes per side.
Don't be afraid of pulling hard once the screws underneath and fender rivets are removed....the skirts will then "pop" off.
Old May 23, 2006 | 01:26 PM
eat rice z33
so i have to remove my little kick plate to get at the frame rivets? and do i have to remove my fender?
Old May 23, 2006 | 01:39 PM
B-Unit's Avatar
B-Unit
you dont need to remove the kickplate, and no u dont have to remove the fender
Old May 23, 2006 | 01:46 PM
Roggan's Avatar
Roggan
You can pull it pretty hard, but make sure not to angle it too much when you pull or you risk damaging it.
/Roger
Old May 23, 2006 | 07:10 PM
A_16's Avatar
A_16
I took mine off and im mechanically inclined sometimes, simple job,
Old Sep 1, 2006 | 08:54 AM
jazz z1's Avatar
jazz z1
Go here, perhaps this will help. If it does, give much props to ANYONE2U. He did the original write-up.
https://my350z.com/forum/showthread....dy+side+skirts
Old Oct 13, 2006 | 03:57 AM
sluggoZ's Avatar
sluggoZ
I appreciate the write-up. Thanks!!
Justin100
Nov 25, 2021 06:26 AM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
