Veilside Ver.3 fender flare question, please help!
Old Jun 18, 2006 | 03:15 PM
ACE_GTS's Avatar
ACE_GTS
Default Veilside Ver.3 fender flare question, please help!
I'm about ready to purchase the Veilside Ver.3 body kit with fender flares but I'm not sure what rime width size I will need with this kit. 20in Volk GT-C's is what I will like to go with. Can someone help me in determining the wheel size that will work with this kit and will I need spacers?
Also, will the original fender need to be cut, to accommodate the 20in wheel?
Thank You in advance.
Old Jun 18, 2006 | 03:17 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
wheel size is not what you should worry about. YOu should worry about the offset. What is your GT-C offset? The flare will comes out from your fender about 10-15 mm. You can add wheel spacer to make it looks flush.
Old Jun 18, 2006 | 05:28 PM
ACE_GTS's Avatar
ACE_GTS
Here is the offset chart for this wheel. Maybe this could help? Thanks
http://www.mackinindustries.com/md/r...c_spec.jpg.gif
Old Jun 18, 2006 | 06:46 PM
Nitrouz's Avatar
Nitrouz
Back to Z
what's the point of going widebody then if you're just gonna put on a 10.5 inch wide rim and having spacers?
call Mackin and have them custom make you a set of 20x13.5's for the rear.
Old Jun 18, 2006 | 06:51 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
20x11 in the rear would be fine too.
Recommended Wheel Fitment with Version 3 Overfender Kit:
Front: 20 x 9.0J (+18mm)
Rear: 20 x 11.0J (-18mm)
Justin100
Nov 25, 2021 06:26 AM
issyz
Jul 2, 2017 03:04 PM
Dymsi
Sep 29, 2015 11:32 AM
