question about JDM clear reflectors
i heard to install these clear reflectors you have to take off the bumper...is this true? an earlier post said it took about 45 min to install...does it really take that long?
'06 Magnetic Black Enthusiast FairladyZ
It isn't as painful as you think...nevermind it is painful, but it's not complicated. Drivers side has enough work area for you to not have to remove the bumper, but the passenger side has the window washer fluid there, and its more of a tight area. That side needs the bumper to be off, you can work with a friend and let him hold it up for you while you exchange the reflectors out. Shouldn't take you more than 45min.
Performance Nissan
Performance Nissan
Its a little harder to get the passenger side on the 06 without takeing it off... Its easy enough to take off the bumper... Just take it off to begin with...
http://www.mynismo.com/products/?id=2739
I've heard of people doing it w.o taking it off. I took mine off though takes under 5 minutes.
WOW 5 minutes! That's pretty fast! I took my white reflectors w/ led today and it took me an hour. This is my second time on doing it too!
i did my 06 within 15 minutes..the pasenger side is a paint... the wiper fluid tank is there...my frien had to pull it back while i put the clear reflectors in.
ps- i took off the front wheels
It was pretty simple for me. About 2 minutes for the driver's side and then once I get to the passenger side it took me a lil bit longer due to the window washer tank. But I didn't take the bumper off (because I did mine at lunch in the parking lot at work). I just had to pull the mud guards back to get back there. I don't think the bumper has to be remove.
^ damn sounds crazy. Anyways did my '06 in about 30 minutes....my bumper was already off since i was installing my CAI...so really it took me about 2 minutes to take the ambers off and then put the clears on. The front bumper is actually quite easy to take off so don't worry about that.
yea it took me about 15-20min to take the bumper off. actually i only took it off half way. did not remove the bolts underneath the bumper. this was my first time taking the bumper off too. very simple.
I put my on just this past weekend and I didn't take the bumper off...driver's side, 5 minutes...passenger's side, 45 minutes and a lot of cussing.
If I were going to do it again, I'd just take the bumper off.
CFAUVEL
Oct 1, 2015 03:20 PM
