OEM 6spd Shift Knob Rattle...is there a fix?
My OEM 6spd shift **** rattles. the only way to cure the rattle is to turn the shift **** tighter, which of course makes it look weird and not feel as comfortable. Orginally i only turned it about an 1/8 of a turn, but then it started rattling again, so now it is at a 1/4 turn.
Does anyone know a fix for this where i can keep my shift **** straight?
Thanks!!
Thanks!!
i got teflon tape from home depot and took the **** off...wrapped the shifter in the teflon tape around the threads and screwed the **** back on...no rattling at all since
something like this:
http://www.drsfostersmith.com/produc...188x003&ctt=60
im willin go tbet that if its ratteling and you can turn it to tighten it up then you should be able to just screw it off. give it a shot if you cant then you may have to use the ways described by others to get it off.
