removing rear hamburger and replacing it with a Z
Old Aug 21, 2006 | 04:28 PM
tripmachine's Avatar
tripmachine
Default removing rear hamburger and replacing it with a Z
I removed the 350z easily with a blow dryer and dental floss..... how about the rear and front hamburgers?? the rear hamburger isn't seeming to want to come off.... any advice? also how do you get the rear Z off the rear strut?? blow dryer? and finally how do you stick the rear Z on? double sided tape? thanks guys!
-j0sh
Old Aug 21, 2006 | 11:12 PM
B-Unit's Avatar
B-Unit
heat it up the same way again. except get a paint scraper or something and put masking tape around it then pry underneath it like a spatula.
-B-
Old Aug 22, 2006 | 06:00 AM
thrill350z's Avatar
thrill350z
the 350z is a breeze to take off but the hamburgers were a *****. I used stronger floss and heated it up longer. you have to pull it towards you instead of down bc there are 2 pins on the rear one to line it up straight. The rear hamburger took about 15mins with a hair dryer and the front took about a min with a heat gun. good luck, just keep heating and pulling. you won't do any damage to the paint with heat and dental floss
Old Aug 22, 2006 | 08:13 AM
tripmachine
ok cool! thanks guys! one more thing.... any idea what I should use to add the rear strut 'Z' on the rear trunk lid?? double sided tape?? or what? also i'm guessing it's pretty easy to get the rear strut Z off as well? Thanks!
-j0sh
Old Aug 22, 2006 | 08:22 AM
Brian@Performance's Avatar
Brian@Performance
Performance Nissan
Yep. It just takes some time to get the hamburgers off. At the end, you could use goop off to clean up the mess.
Old Aug 22, 2006 | 01:10 PM
tripmachine
what about adding the 'Z' to the rear hatch??... I want to add the Z to cover the two holes the hamburger leaves... what product should I use to stick the Z on...? thanks
Old Aug 22, 2006 | 01:16 PM
Dr. RPM's Avatar
Dr. RPM
I've always found the 3M brand of 2-sided body moulding tape to be the best for strength...
Old Aug 22, 2006 | 11:25 PM
steveiZdaman's Avatar
steveiZdaman
thats what i used on my Z emblem...very storng
Old Aug 22, 2006 | 11:27 PM
Roger V's Avatar
Roger V
crazy glue.
Old Aug 22, 2006 | 11:45 PM
Z33Benny's Avatar
Z33Benny
crazy glue will definately leave a horrible crusted over mess if you ever want to take the emblem off. Use 3M double sided body molding tape. You should be able to find it at any autoparts store in their "paint/body" section.
Old Aug 23, 2006 | 05:13 AM
Mapleleaf's Avatar
Mapleleaf
Here is something I am working on a new Z Emblem made out of Aluminum just trying to get the curve right and will be avialable in certain colors
Attached Thumbnails removing rear hamburger and replacing it with a Z-z-emblem.jpg
Old Aug 23, 2006 | 06:29 AM
cRAYz4life's Avatar
cRAYz4life
The Z on the rear strut brace is melted on. You hve to pull the whole plastic cover off and on the underside of it you will see what I mean. posts on the emblem go through the cover and then they are melted flat to hold it on.
Old Aug 23, 2006 | 06:37 AM
Anyone2u's Avatar
Anyone2u
Charter Member #82
Nice job Terry! I was wondering how long before someone would come up with something made out of a "metal". The Z that comes off of the rear strut bar and the "cheap" black door sills (both Zs are the same size) are plastic and don't stand up to the elements too well. Hurry and get that sucker in production and post up some pictures! You will be making a red one, right?
Old Aug 23, 2006 | 06:49 AM
Mapleleaf's Avatar
Mapleleaf
Yes I will be doing a Red , Blue and Polished Ones. I have Orange one's on my Sill Plates & Rear Strut Bar already
JjL
East Canada
Jun 12, 2019 03:04 AM
hulkout
Apr 28, 2017 09:00 PM
StateNuke08
Oct 31, 2015 05:01 AM
kyin
Oct 15, 2015 05:54 AM
FromGtoZ
Sep 20, 2015 03:41 PM
