Remove Window Molding
on
How do you remove the door molding for the window on the Z.. I was going to have the door painted and don't want to have it just taped off. Does is slide out or what??? Thanks..
http://img122.imageshack.us/my.php?i...toswndwim7.jpg
on
Well i figured it out. You just pull real hard toward the door handle and it slides right out.... Just lettin you all know in case you ever have to take it off.
Did you remove the door panel as well or did you only slide it off away from the side mirror? I ordered a replacement and it should arrive tomorrow. The official document says, in order to remove the 'side window outside moulding', you have to remove the door panel too.
Gruppe-S
Body Interior
13
05-16-2016 10:42 PM
04-04-2016 07:52 AM
