varis air duct + tube
Old Sep 26, 2006 | 04:51 PM
whoaishjustin's Avatar
whoaishjustin
Default varis air duct + tube
i just got it in the mail today and was wondering how to install the tube..would i have to take o0ff the front bumper to do this? and one more thing, will the exacto knife struggle to cut through the bumper?
Old Sep 26, 2006 | 05:06 PM
bam025's Avatar
bam025
ok...slow down....do a search in the Body/Exterior forum. There are several good write ups. You do not need to take off the front bumper. An exacto knife porbably wont cut through your bumper. I used a dremmel, BUT FIRST PRACTICED on some old plastic I had laying around the house. Read the write-up, drink a beer, and go for it. ....drew
Hella's Avatar
Hella
A fresh blade will cut through it easily.
Old Sep 26, 2006 | 05:22 PM
nizm350's Avatar
nizm350
yes a sharp exacto blade will cut through it pretty easily. btw where did u get the tube?? im looking for that piece.
Old Sep 26, 2006 | 05:44 PM
whoaishjustin
i got the tube at www.evo-r.net . go to the 350z an then the bottom middle will be the air duct, click on that an its the second one.
BTW, for anyone with an air duct...im not sure if you gain a little power or any at all, but i was just curious to know if you noticed anything different while driving..in example, louder? etc
Old Sep 27, 2006 | 05:47 AM
THE TECH's Avatar
THE TECH
I have a tube for sale if anyone is interested.
Old Sep 27, 2006 | 06:01 AM
MustGoFastR's Avatar
MustGoFastR
Not sure about a little Exacto blade; I did an install for a friend and used a utlity knife with a fresh blade. Works like a charm. For the connector tube, you don't need to take the bumper off, but you'll have to loosen everything holding it on on the driver's side and accross the front so you can pull the bumper away a bit in order to get the tube in there.
Old Sep 27, 2006 | 06:43 AM
THE TECH's Avatar
THE TECH
I'm partial to the Dremel.
Old Sep 27, 2006 | 07:51 AM
bam025's Avatar
bam025
Why are you selling the tube tech?
Old Sep 27, 2006 | 07:58 AM
MustGoFastR
For this job, a sharp blade works best, IMO. Dremel cutting disc melts plastic, leaves burrs and makes a mess and one of those sideways cutting drill bits is hard to control direction. I just traced the template with a dry-erase marker and cut it with the utility knife in under a minute. Cut and fit was perfect.
Old Sep 27, 2006 | 08:09 AM
THE TECH's Avatar
THE TECH
Doesn't work so well with my Vortech.
Old Sep 27, 2006 | 03:51 PM
whoaishjustin
i just finished installing my varis air duct, but i dont kno how to fit the tube in there.
Old Sep 27, 2006 | 03:58 PM
THE TECH's Avatar
THE TECH
It was mentioned above. You'll need to loosen the bumper some on the driver's side to allow you to get the duct in there. The best way to secure the duct though is to take off the bumper, but either way will work.
Old Sep 27, 2006 | 04:44 PM
NA&CH's Avatar
NA&CH
How much Tech?
350Z_Al
Oct 29, 2020 07:44 PM
sales@czp
Sep 23, 2019 03:30 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
