Need advice on rear hatch shocks
Old Oct 2, 2006 | 11:35 PM
nofeardude87's Avatar
nofeardude87
Default Need advice on rear hatch shocks
Hey, so I have a common problem with the rear hatch shocks not being able to hold up the hatch. I'm just wondering if anyone has a quick diy to keep it up for a car show as I want to show the system in the hatch. Thanks!
Old Oct 3, 2006 | 12:54 PM
nofeardude87
anyone?
Old Oct 3, 2006 | 06:28 PM
Agentman03's Avatar
Agentman03
I Think if you Remove the inside Plastic Liner on the Hatch carefully with small screwdrivers ,then there are weights bolted on with a # 10 screw/ socket, I Found this out when installing My New Nismo Rear Spoiler. and moved the weights and the Hatch kept droping down on me with the wiight of the new spoiler ?? also had to do the penny thing to adjust for opening the hatch,, see earlier foram
Old Oct 3, 2006 | 09:23 PM
nofeardude87
so when you took out the weights it still kept dropping?
Old Oct 3, 2006 | 10:24 PM
evobunny's Avatar
evobunny
here a quick cheap fix I had to do for a show cause of the hatch keep dropping on me. and I had never had that happen before so I use some tape and tape where the rod and shaft meet. it helps. just make sure the judge dont see it.haha
Old Oct 3, 2006 | 11:06 PM
nofeardude87
I think I know what you are talking about. Must have been some strong tape. What kind did you use?
Old Oct 4, 2006 | 01:46 AM
showstoppertk's Avatar
showstoppertk
it probably wouldn't fly in a car show, but I just use half of a pool stick to hold my hatch open for extended periods.
Old Oct 4, 2006 | 03:54 AM
Mike Wazowski's Avatar
Mike Wazowski
or you can get the higher pressure hatch shocks from Performance Nissan
Old Oct 4, 2006 | 07:35 AM
Brian@Performance's Avatar
Brian@Performance
Performance Nissan
http://www.mynismo.com/products/?id=4660
Old Oct 4, 2006 | 10:33 PM
evobunny's Avatar
evobunny
I use some duck tape cause that all I had at the car show.. just a small strip. but you might try electric tape so it will match the black damper.
Old Oct 4, 2006 | 10:44 PM
doskiez's Avatar
doskiez
there is a clamp that is used specifically for holding gas lifters in an open position, but i am not sure where to get it. I used them all the time on E 30 BMW hoods at work.... they had a nasty habbit of falling on you
Old Oct 5, 2006 | 12:12 PM
evobunny's Avatar
evobunny
yeah you can use clamp but that would just look ugly for a car show. haha or you can do this. one of my friend has this really old car. and his dampers went out. so he bought a tube and slip it over the damper. so when he open the hatch he would slide the tube to the top and rest it on the outer part of the shock.
Rowlett
Misc.
Oct 2, 2015 10:38 AM
