What size bolts needed for invader side skirt wings
Here is a link to what I am talking about.
http://cgi.ebay.com/ebaymotors/JDM-3...34915073QQrdZ1
It says it is "direct bolt on" but it does not inlcude any hardware. Just wondering if anyone knows what size nuts and bolts or what I need to get to get this mounted.
Originally Posted by Chebosto
those use your OEM bolts that attach your factory side skirts on. if you look under your car, you will understand why there is no need for additional hardware.
I really didn't get much of a chance to look and maybe they didn't look very hard either.
Getting under the car is not a very easy task and since no instructions were included so wasn't sure what I needed to do.
Originally Posted by TSur
I did have my rims put on yesterday and was going to have them install these for me but they said there was nothen to bolt this to and they would need to put holes in the sideskirts...
your shop obviously did not look at HOW the stock sideskirts are installed.
see the shiny bolts along the underside, next to the lift points? those are where the wings attach to.. granted the wings you bought have holes predrilled in them already.
you dont need a lift to get to those bolts, just have to lie on the ground.
That pic helped alot. I got under the car lastnight and it was easy to see where this goes. (The shop must have not understood how they went on because that is just 2 easy!!!)
I tried to install one of them but found the bolts to be just a bit to short to start to thread in. So I need to get some about 1/4 longer and I will be set.
Other then finding some bolts that work this should be very easy! I thank you for your help!
Subarism
East Canada
Sep 23, 2015 06:09 PM
hardkicks
Sep 20, 2015 12:28 PM
