Just installed 5/16 Spacer, Feeling a slight vibration in Steering wheel above 75
Old Oct 22, 2006 | 01:20 PM
DanielW's Avatar
DanielW
Default Just installed 5/16 Spacer, Feeling a slight vibration in Steering wheel above 75
hey guys I just installed a spacer from motordyne this weekend. I had read on here that if the strut bar isn't properly tensioned after reinstallation that it can cause vibrations. I think I might have been looking for this after the install and that may be why I'm feeling it, but when i got on the freeway and got above 75 a felt a very slight vibration in the steering wheel. Was this always there or do I need to adjust my strut bar? If so what adjustments should i make?
Old Oct 22, 2006 | 02:26 PM
Mazinger Z's Avatar
Mazinger Z
Make sure that your strut bar is not touching your upper plenum. There should be at least a 2mm gap in between to allow the engine to move a little bit. Use all the washers that were provided, and adjust the jam nuts on the left side of the strut bar.
You can also try taking off the strut bar completely and driving it to 75mph or whatever speed you felt the vibration to see if it's actually the strut bar that's vibrating. Good luck!
Old Oct 22, 2006 | 02:35 PM
DanielW's Avatar
DanielW
do the strut bar bolts have to be torqued down to a certain spec? I thought it was jus tthe plenum bolts that you had to use the torque qrench on.
Old Oct 22, 2006 | 03:49 PM
JonsilvZ's Avatar
JonsilvZ
I have the Motordyne 5/16 spacer and I hit 140mph today there was no vibrations. Maybe your wheels need balancing.
Old Oct 22, 2006 | 08:07 PM
stylinZ's Avatar
stylinZ
Where the heck did ya do that kinda speed? I don't think I'd ever get to go that fast....around here.
Old Oct 23, 2006 | 06:54 AM
DanielW's Avatar
DanielW
yeah i don't hear a rattling or rubbing sound at all. I'm thinking it may have been when i hit a crucial pothole in the road a week or two ago and this is my first time noticing the vibration since it was so slight an I'm looking for it now. Could the pothole have thrown me off balance?
Old Oct 23, 2006 | 10:00 AM
mdracer76's Avatar
mdracer76
more than likely the pothole has done a job on your alignment....
.. oh.. and when I go 567mph in my Z i get a slight vibration.. same thing
Old Oct 23, 2006 | 05:01 PM
JonsilvZ's Avatar
JonsilvZ
There is one place on LI where is safe with no cars and cops. Which I'm not mentioning.
aarrgghh
May 1, 2022 11:04 AM
reno56
Interior
17
Nov 20, 2015 05:21 PM
pdexta
Sep 14, 2015 11:27 AM
Beater350z
Sep 9, 2015 03:36 PM
