Seats Anyone?
Old Mar 16, 2003 | 11:15 AM
msink's Avatar
msink
Default Seats Anyone?
Does anyone know how much the stock seats weigh (with or w/o air bags) Mine has them. Id like something different, but woul also like to know how much they weigh so I can save some weight. on the new ones.
Thanks,
Mark
Old Mar 16, 2003 | 04:04 PM
Mr Fairlady's Avatar
Mr Fairlady
not sure on weight but man,..the new COBRA "Misano" Seats that came out---they are Badass---even avaliable in Leather for those who like it---I hate Leather
But I would say--ya can't go worng w/ a Set Of RECARO's....they are the Shizzle and thats about the only set I would even think of puttin in the Z.Like the JDM DC2 ITR's--Blk w/ Red Stich for me please!
Old Mar 17, 2003 | 12:07 PM
msv's Avatar
msv
Stock seats without airbags are as follows:
Driver's: 36.55 lbs.
Passenger's: 36.15 lbs.
I put Sparco Roadsters (black with silver shells) (http://www.sparcousa.com/pseats_street.asp?id=97) in my car. The bare seats weigh 16.75 lbs each, and with the custom mounts that I made, they are 22.25 lbs.
Old Mar 18, 2003 | 08:32 AM
msink's Avatar
msink
THANKS!!! (for the weights) 36 lbs, cool, so I CAN save some weight. I had been eyeing the Sparco Fighter. Are you able to open the compartment behind the passenger seat all the way? What did you do for mounting rails? Did your seating height change any?
Thanks,
mark
P.S. Im not getting emails notifying me of new posts in my threads, is this feature working for others?
Old Mar 18, 2003 | 08:44 AM
msv's Avatar
msv
I made my own mounts for the seats. I would not recommend using the seat bases that Sparco has, as they are much too heavy. I lowered the seating position about an inch since I'm relatively tall and wanted to see something out the rear window besides the pavement 10 feet behind the car. And for a lower CG of course.
I can open the storage compartment, but not all the way. I can still access it, though. It is fine for me, since I don't carry a lot of crap in the car anyway.
The fighter's should save at least as much weight.
Old Mar 18, 2003 | 11:39 AM
msink's Avatar
msink
Your own mounts eh? Very good. Do they slide?
Are u using the stock belts? I would need a harness with the Fighter, but yours look like stock belts might work also. Does the lap belt lay across you OK? It looks like it might not be against my body, Im 5'7 28" waist, 130lbs.
Old Mar 18, 2003 | 11:51 AM
turbo03's Avatar
turbo03
Sparco is in the process of releasing mounts and sliders for the Z. I spoke to Adam at Z-1 Performance and he said he should have them in next week. Give him a call or email him for pricing an avaliabity.
1-631-863-3820
z1sales@z1auto.com
thanks,
Turbo03
Old Mar 18, 2003 | 12:02 PM
msv's Avatar
msv
I had a set of the Sparco mounts but didn't use them because the build quality isn't very good, and they are very heavy. Sparco doesn't make them in-house.
I made my mounts without sliders, as the Sparco sliders weigh an additional 5 lbs per seat. No one but me drives my car, so it's a non-issue for me.
I am using the stock belts, and since the recepticle bolts into the seat, I had to integrate that feature into my mounts. The belt is perfect. I am 6'-1", 185 lbs, 30" waist, and the Roadster fits perfect. It fits smaller drivers just as well. If yours is a street car, I wouldn't recommend a Fighter since it is going to be very hard to get in and out of. The Roadster is nice because it is a shell seat and has awesome lateral support, but is constructed with entry and egress in mind.
Old Mar 18, 2003 | 12:37 PM
msink's Avatar
msink
So the Sparco rails are heavy... Then add 5 lbs for the sliders. How does this weight compare to the stock pieces that I would be replacing? If its the same or less, I guess its OK.
Mark
Old Mar 18, 2003 | 01:18 PM
msv's Avatar
msv
You'd still be saving a bit of weight but not much, less than 5 lbs. a seat. I don't know exactly what the fighters weigh.
Old Mar 18, 2003 | 01:57 PM
msink's Avatar
msink
I wasnt clear in my last post.
Am i correct in assuming that the aprco rails and sliders replace stock parts?
If so, what do the stock rails/sliders weigh?
The seats are 36 lbs v/s 14 lbs for the Roadsters
The rails i install/replace are xxx (stock) v/s yyy (sparco w/ sliders)?
Thanks,
Mark
Old Mar 18, 2003 | 02:55 PM
msv's Avatar
msv
The 36.X lbs per seat is the complete weight.
The Sparco bases will bolt into the stock locations on the floor boards vacated by the stock seats, and then the Sparco seat and sliders bolt to that.
You are looking at 36 lbs vs. 15 lbs (seat) + ~11 lbs (base) + 5 lbs (sliders)
Old Mar 18, 2003 | 06:40 PM
msink's Avatar
msink
Wow, heavy base! Thanks a lot for your input. I've been wanting to start a database of parts and weights for piecs of the Z.
Mark
NiLL
Nov 29, 2021 02:26 PM
3vilbunny
Jul 18, 2017 05:10 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
AngryZ
East Canada
Sep 16, 2015 05:08 PM
