Hid Instal ??????????
Old Nov 14, 2006 | 12:53 AM
TimeAttkZ's Avatar
TimeAttkZ
Thankz Ztalker
Old Nov 14, 2006 | 05:15 PM
TotalChaos's Avatar
TotalChaos
so a little update on my install. Went almost flawlessly... However, I also went with the "hardwire" way that timeattkz did. I was having some trouble with them connecting the "instruction" way, so I just resorted back to good ole direct lines in and out.
They look amazing though... thanks again Chuck!! GREAT product.
Old Nov 14, 2006 | 05:25 PM
gNaRKiLL's Avatar
gNaRKiLL
Im glad it worked out for you.
I guess the only way I can see that this would work is that since some Z's come with HID's stock the wiring and circuitry is probably designed to accomodate the HID ballasts and ignitors.
I might even go in and change mine to this method in order to get rid of that harness.
Old Nov 14, 2006 | 05:28 PM
TotalChaos's Avatar
TotalChaos
yeah... you really dont need the harness whatsoever! Just the ballast, bulbs, and the wires that are attached to them. Reallllllll simple. (much more clean looking as well)
p.s. I meant to ask you if you needed some pictures of the 8k setup on a Z? Not sure if you had one to show people that were interested.
Old Nov 14, 2006 | 07:02 PM
gNaRKiLL's Avatar
gNaRKiLL
Hey the more pictures the better.
Old Nov 14, 2006 | 08:11 PM
NaNa-Papa-J's Avatar
NaNa-Papa-J
Smile
Hey everybody,
I just got the lights (8000k) in from Infern0 and installed them tonight. After looking at gNaRKiLL's instructions, they went together very easily. I didn't have the sticky tape for the ballasts, so I had to use the brackets. Anyways, I didn't have an issue using the extra harness. I figured that since it had a relay and fuse that it would be extra protection for the lights. They look fantastic! I'll post some pics this weekend.
I appreciate the wiring picture post gNaRKiLL...it helped a ton.
A definite must mod for the $$$...
Pleask
Dec 21, 2021 03:17 PM
