Burning Smell
Old Dec 11, 2006 | 05:08 AM
jtabraham's Avatar
jtabraham
Default Burning Smell
I'm getting this slight burning smell, almost like burnt popcorn coming from my vents when I have the heat on. This smell doesn't appear when I run the temp controls at cooler temperatures, so I'm assuming the smell is coming from the heater core.
I'm thinking that there may just be a bunch of dust buildup on the heater core itself, and it's getting hot enough to singe it and give off the smell.
Any one with similar problems, or experience? I would rather not pull off the dash to dust out the heater core, since this isn't an overwhelming problem.
Old Dec 11, 2006 | 06:34 AM
davidf's Avatar
davidf
If it's been a while since you've used your heater thats probably it. I get that smell in my home unit the 1st of every winter.
Old Dec 11, 2006 | 06:44 AM
jtabraham's Avatar
jtabraham
I've been using my heater every day now for the past month (cold up here in Massachusetts) The smell comes on and off...maybe someone dumped some jiffy pop in my vents
Old Dec 11, 2006 | 03:37 PM
VIZAGE's Avatar
VIZAGE
Is that with or without butter?
Old Dec 11, 2006 | 04:48 PM
jtabraham's Avatar
jtabraham
kettle corn i believe
Old Dec 11, 2006 | 04:58 PM
stein's Avatar
stein
On the ride home today I smelled pepperoni, I was so wanting to eat pizza when I got home!
Maybe it's in the air, that's what I figure it was with the pepperoni...
Old Dec 11, 2006 | 05:08 PM
jtabraham's Avatar
jtabraham
I don't think it's something in the air, because it doesn't seem to be isolated to any particular location. I guess it smells like a milder version of when a bug gets stuck in a halogen torche lamp.
Old Jan 15, 2007 | 06:41 AM
jtabraham's Avatar
jtabraham
the smell stopped but reappeared again yesterday. I took a look in the engine bay and it smelled a little more noticebaly than it did in the cab. It definitely smelled of burnt rubber, so I checked my belts for damage, and they didn't look to be frayed or making contact with anything (I replaced them 3 months ago).
Checked for any fluid leaks in the bay, but couldn't see any. I'm wondering if one of my hoses or vaccum lines is touching the exhaust manifold or exhaust causing this? Would a bad seal do it?
Old Jan 15, 2007 | 12:25 PM
acelesson's Avatar
acelesson
I dont know but I can tell you I get that burning smell from the heater as well.
Old Jan 15, 2007 | 01:03 PM
SpoilsofWar's Avatar
SpoilsofWar
same here, it comes and goes. But I have an '03 and the car hasn't burst into flames yet..
Old Jan 15, 2007 | 06:56 PM
acelesson's Avatar
acelesson
Anyone take their car in yet for this? Im thinking of schedualing an aptmnt with a local Nissan dealership. I just bought my 04 so I want to make sure its ok.
Old Jan 15, 2007 | 07:17 PM
DaveZ06's Avatar
DaveZ06
its the smell that was added to the heaters by nissan so you don't fall asleep from long drives.
Old Dec 19, 2015 | 12:38 PM
realmc's Avatar
realmc
had same problem. "valve covers leaking oil" got worse over time. cost me $900.00 at Nissan dealer here in Houston. 2005` 350z. problem fixed. good idea to have spark plugs changed while this is done no extra charge for labor.
apex locator
Jul 23, 2021 02:27 AM
3vilbunny
Jul 18, 2017 05:10 PM
allmycarsdie
May 13, 2016 04:38 PM
smithmt3
Sep 11, 2015 08:25 PM
