Bought CF hood, new seals or no? hood struts & pins??
Old Jan 15, 2007 | 08:17 AM
Nic@CiNcity's Avatar
Nic@CiNcity
Default Bought CF hood, new seals or no? hood struts & pins??
So now that my TT is listed for sale, i figured i should add pics ASAP. First, i wanted to clean it up a bit and buy a new CF hood (Bought the TS style from CarbonLimited). My question is on the seals. Can i re-use the stock seals or do i need to buy new ones?? Also, I think i'm going to go with hood struts and hood pins. Can i make my own struts with hatch struts or do they need to be specific for what ever reason? Lastly, hood pins. Any recomendations?
Old Jan 15, 2007 | 08:23 AM
Jim@Showstoppers's Avatar
Jim@Showstoppers
I like the Aerocatch pins. They are the manufactures of the Top Secret pins but much less.
Old Jan 15, 2007 | 08:27 AM
Nic@CiNcity
Link? Nevermind, found a set. Expensive! wow.
Old Jan 15, 2007 | 08:34 AM
Jim@Showstoppers
Originally Posted by Subrwho
Link?
www.aerocatch.com
Old Jan 15, 2007 | 08:35 AM
mario23's Avatar
mario23
http://www.aerocatch.com/
Old Jan 15, 2007 | 08:49 AM
Chebosto's Avatar
Chebosto
you can remove and reuse the stock weather seal from the stock hood. you do no need to repurchase new ones, if you do not want to DRILL into your CF hood,
you can use 3m heavy duty weatherproof double stick tape (from home depot) to attach the weather strip rubber.
as for hood pins. SPARCO sell the hood pins that fit exactle into the radiator support frame with no extra drilling on the frame side.
pin#1( pass side)
the driver side hole is right above the intake hole...
sparco pins retail for like $30-
Old Jan 15, 2007 | 08:53 AM
Nic@CiNcity
Hmm.. I'll have to look into those. Thanks for the info on the seals. That helps alot.
Old Jan 15, 2007 | 04:46 PM
Mazinger Z's Avatar
Mazinger Z
^Hey, that looks like mine Sparco hood pins work really well. Makes me feel alot better when I'm driving fast.
Old Jan 15, 2007 | 05:38 PM
horse110's Avatar
horse110
+1 on sparco pins
Old Jan 16, 2007 | 06:50 AM
THE TECH's Avatar
THE TECH
I have both and haven't decided which ones to use. Sparcos do less damage to the hood but don't look as clean/nice. The Seibon hoods also have the indentions where the factory hood seal snaps into. You can just drill or dremel these small holes and your weatherstrip will pop right on.
Old Apr 21, 2007 | 04:17 PM
lovetoclown's Avatar
lovetoclown
Anyone have pics of the sparco pins installed???
Old Apr 21, 2007 | 07:58 PM
MethodRN's Avatar
MethodRN
For Sale
Does the aerocatch hood pins need drilling into the frame?
Uriyo_
Sep 8, 2021 08:46 AM
Fixxxercask
Nov 9, 2015 11:10 AM
350z82
Oct 1, 2015 06:25 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
