Problem removing oem antenna
Old Feb 22, 2007 | 05:05 AM
NISMO604's Avatar
NISMO604
Default Problem removing oem antenna
so, ive read that the removal of the antenna is pretty easy? just twist it off?
ive tried that in both directions, and it will not come off..i hope it not sealed with anything.
any suggestions???
Old Feb 22, 2007 | 05:06 AM
Jay'Z's Avatar
Jay'Z
Wow...........
michaeljr6's Avatar
michaeljr6
it's super easy.....you must be a girl...
lol
jk, turn it counterclockwise and try it really hard.
Old Feb 22, 2007 | 05:07 AM
michaeljr6's Avatar
michaeljr6
btw if you bought it used...the person before you may have put loctite on it...and if that happened, sucks for you.
Old Feb 22, 2007 | 05:13 AM
savvy's Avatar
savvy
twist you girly man, no magic to it
Old Feb 22, 2007 | 05:44 AM
ZCARBANDIT's Avatar
ZCARBANDIT
righty tighty, lefty loosey.
Old Feb 22, 2007 | 06:31 AM
NISMO604's Avatar
NISMO604
ya, i did buy it used...
dammit...i need to remove it...i wanna put a shorty on.
if it is put on with loctite , what can i do to remove it?
Old Feb 22, 2007 | 07:34 AM
djnc's Avatar
djnc
LOL!...why would someone put loctite on the antenna?...maybe try using some pliers to get a better grip...if there is loctite on there, i'm sure sure what you can do
Old Feb 22, 2007 | 09:46 AM
DustinZ33's Avatar
DustinZ33
Just grip it like a man and turn it. I barely had to use any force take mine off.
Old Feb 22, 2007 | 09:48 AM
Brick-Z's Avatar
Brick-Z
Vice-grip
Old Feb 22, 2007 | 09:54 AM
michaeljr6's Avatar
michaeljr6
we need a DIY for some ppl
Old Feb 22, 2007 | 10:24 AM
coolblue830's Avatar
coolblue830
Just make sure you are firmly grasping the base and twist (ouch that sounds painful)... At first it may seem tight if the guy never screwed it off to begin with but should come off no problem. Not sure why anyone would put locktite on our stock antenna tho... who would steal that mile-high thing? My s2000 one tho...
Old Feb 22, 2007 | 12:52 PM
joegengsta's Avatar
joegengsta
this is a common problem, you're suppose to tap the bottom edges with a sledge hammer and then have a friend stand on the truck and pull straight up. a few dents in the trunk is normal and don't worry if your neighbor looks at you and call the psychiatrist.
Old Feb 22, 2007 | 01:49 PM
Vertex350's Avatar
Vertex350
Dude, use both hands and some WD40 at the base. Make sure you're not screwing off the part that touches your fender. The antenna only please!
Old Feb 22, 2007 | 01:54 PM
CEO350Z's Avatar
CEO350Z
That's bad juju
just be sure to clean up after yourself. a warm towel usually works
Old Feb 22, 2007 | 02:38 PM
tomiegunzz's Avatar
tomiegunzz
You have to do a couple of push ups first to get the blood pumping in your arms. Then you have to pound your chest and let out a cry of a beast. Then give it a try. If that doesnt work then your screwed buddy.
Old Feb 22, 2007 | 02:39 PM
NISMO604's Avatar
NISMO604
should have no problem removing it, so i dont know why im having probs with it...argh.
i had a s2k antenna on my celica before...it was fun jacking s2k antennas..oops did i just type that...???
im gonna try again when i get home tonite.
Old Feb 22, 2007 | 02:48 PM
oclor's Avatar
oclor
Old Feb 22, 2007 | 03:05 PM
CEO350Z's Avatar
CEO350Z
That's bad juju
karma comes back like a boomerang
seriously, dunno why you're having problems
Old Feb 22, 2007 | 03:14 PM
coolblue830
Originally Posted by oclor
+1 damn people, the thing costs at most like $25... have a little dignity...
