Center console question
Old Feb 25, 2007 | 09:21 PM
Lancaster's Avatar
Lancaster
Default Center console question
Quick question please if anybody is up right now and knows the answer~
I'm trying to remove the center console (not the vertical instrument panel, the horizontal trim from the shifter back b/t the seats)
I reaaly don't want to engage in the hassle of removing the shifter trim (I'd have to take off the shift ****) just to get the console out of the way.
It appears that the only thing keeping me from doing this is a thin piece of plastic linking at the front of the console (appears to be support for behind the AC controls).
Is this linking plastic really necessary? If i cut it out would I be messing up something I'm not aware of?
Thanks in advance for any insight
Old Feb 26, 2007 | 06:52 AM
MustGoFastR's Avatar
MustGoFastR
You can cut that piece; it won't hurt anything.
You can also remove the shift cover panel without removing the shift ****. Just lift and twist it enough so you can remove the 8 small brass screws underneath that hold the brushed AL trim ring and shift boot to it. The panel can then be removed, leaving the trim ring, shift boot and shift **** in the car. This is usefull to those of us that have shift ***** that simply will not come off without destroying them.
Old Feb 26, 2007 | 07:13 AM
Greedy4nismo's Avatar
Greedy4nismo
worked for me when i was rewiring the audio
Old Feb 26, 2007 | 10:01 AM
Cannysage's Avatar
Cannysage
sort of off topic, but can you get CF center console?
Old Feb 26, 2007 | 10:41 AM
MustGoFastR
No overlay kits are available, but you can get Suite-E Graphics to do a custom job or Tonester can prob do it for you.
Old Feb 26, 2007 | 03:52 PM
davidf's Avatar
davidf
That should be cheap.
Old Feb 26, 2007 | 10:36 PM
Lancaster's Avatar
Lancaster
great, thanks u guys
issyz
Jul 2, 2017 03:04 PM
kyin
Oct 15, 2015 05:54 AM
Mattg350z
Oct 2, 2015 06:51 AM
Depravity
Oct 1, 2015 04:49 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
