Power Seat Stuck
Old Mar 2, 2007 | 06:44 AM
TampaZ's Avatar
TampaZ
Default Power Seat Stuck
So last night I finished my subwoofer/amp install and everything went beautifully, then I went to move my power seat back after taking my bose sub out and it's stuck and wont move. It'll slide back and forth, which makes me think its not a fuse or power issue, but it's stuck way forward and it's undriveable. Has anyone had this problem? Does anyone know if theres a way to manually lean it back? I was wayy too tired to mess with it last night after finishing the install.
Old Mar 2, 2007 | 04:52 PM
Barmats's Avatar
Barmats
Generally, there's no way to manually crank the recline on a power seat. It's a different motor and assembly for recline than it is for fore/aft -- my guess is your wiring harness and/or connector isn't pushed all the way in. It sounds like a connection problem. Just in case, however, you should check the fuse panel.
3vilbunny
Jul 18, 2017 05:10 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
codek
Sep 28, 2015 03:03 AM
