Quick question about installing eyelids..
Old Mar 3, 2007 | 03:58 PM
Jedi007's Avatar
Jedi007
Question Quick question about installing eyelids..
ok, i know.. asking a question about installing eyelids has noob written all over it.. but...
i had a set of painted eyelids on my last car and i used some thick glue that came with them.. not sure of the brand since it was all in german..
I have a set i want to install on the Z and i'm wondering what others have done to attach them. I feel like 3m tape just isnt gonna cut it. i'm also thinking about the removal in the future... dont wanna use something that will permenatly f-up my headlight plastic.
maybe the glue used for emblems?
any suggestions?
Old Mar 3, 2007 | 04:34 PM
Mazinger Z's Avatar
Mazinger Z
Don't use glue. I used the 3m double sided tape. You don't want to use glue since you're probably going to want to take them off someday. 3m works fine, just make sure it's stuck all over and no one can rip it off. It takes a lot of effort to rip off anyway so you should be fine.
Old Mar 3, 2007 | 04:44 PM
zstreet86's Avatar
zstreet86
does anyone know if applying the tape to the headlight will damage it in the long run if i decdie to take them off for any reason?
Old Mar 3, 2007 | 04:54 PM
lunartick13's Avatar
lunartick13
I too just ordered a set, which I will be intalling soon. Noobie or not this is a good valid question. 3M doulbe sided tape should do the trick..
Old Mar 3, 2007 | 05:35 PM
Mazinger Z's Avatar
Mazinger Z
No it shouldn't. I took them off maybe 2-3 times and reinstalled them. If there is residue, soak it with some windex and scrape w/ your fingers and it should come off pretty easily.
Old Mar 3, 2007 | 06:02 PM
Vas@Extended's Avatar
Vas@Extended
Vendor - Former Vendor
3M tape for sure!.. I had eyelids on my se-r... and they were rock solid... it took me maybe 10-15? min to remove them after 4 months... so i say go for 3M.
Old Mar 5, 2007 | 04:54 AM
Takhteh's Avatar
Takhteh
OFF TOPIC... Jedi007, Empty your Mailbox!! I've been trying to PM you!
Old Mar 5, 2007 | 05:04 AM
reptile718's Avatar
reptile718
I have had my eyelids for about 6 months with 0 problems. I used 3m tape around the boarders and its rock solid.
Old Mar 5, 2007 | 05:12 AM
jtabraham's Avatar
jtabraham
Here is portion of the spec sheet for one specific model of 3M tape. As you can see, with an appropriate amount of tape it should provide you with MORE than enough adhesion.
Old Mar 5, 2007 | 06:28 AM
Greedy4nismo's Avatar
Greedy4nismo
holy cripes... 50 lbs per inch (25/0.5) at room temp? yeah. i'd say that's more than strong enough. gonna take a decent amount of force to take it off too seems like. CLEAN your headlight and the bottom side of the eyelid before applying the tape. It will increase the adhesion.
Old Mar 5, 2007 | 07:18 AM
JDMZ33's Avatar
JDMZ33
yea, 3M is fine.
Old Mar 8, 2007 | 12:20 PM
Jedi007's Avatar
Jedi007
thanks a bunch guys. all that info puts my mind at ease about using 3m tape.. i just had visions of them flying off on the highway or something!!
now if it would only get a little warmer so i can get outside and install the pile of stuff i have for my Z!
Mattg350z
Oct 2, 2015 06:51 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
TrackFiddy
Sep 24, 2015 11:40 PM
NYGiants0186
Sep 8, 2015 10:37 AM
