Handbrake too high?
Old Mar 22, 2007 | 10:00 AM
driverx2010's Avatar
driverx2010
Default Handbrake too high?
Does anyone here have problems with thier handbrake pulling up too high? Mine does that and I was wondering if there was anyway to adjust it.
Old Mar 22, 2007 | 10:03 AM
Sean's Avatar
Sean
I have not looked ,but there is usually a turnbuckle in the cable under the car. You can adjust that and the handle won't pull up as far.
Old Mar 22, 2007 | 10:23 AM
Black_Sunshine's Avatar
Black_Sunshine
6-7 clicks is the proper amount of travel IIRC. I believe the adjustment can be done on the lever, under the console. I'll check the manual.
Old Mar 22, 2007 | 10:29 AM
Black_Sunshine
Page from the 2005 manual attached.
File Type: pdf
Old Mar 22, 2007 | 12:15 PM
Vertex's Avatar
Vertex
Take out the ashtray/coin tray and adjust the nut you see in the back with a 10mm socket wrench. Ours is set to 3-4 clicks.
Old Mar 22, 2007 | 01:05 PM
driverx2010
Smile
Thanks Yall...you guys kick ***
AbrasiveRaysive
Sep 20, 2021 02:29 PM
Alexreyes
Sep 30, 2015 11:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
