View Poll Results: Airduct Titek? or Varis
Titek
30.43%
Varis
16
69.57%
Voters: 23. You may not vote on this poll
Airduct Titek? or Varis..
Old Mar 29, 2007 | 12:20 PM
behjjeh's Avatar
behjjeh
Vendor - Former Vendor
Default Airduct Titek? or Varis..
I looking to buy airduct for my car..
one is made by Titek and one is Varis.
looks like
Varis is
about $100 more, but looks like better air flow.
Titek (my friend bought one..)
cheap, but not sure about fit ment.. there are some gaps between airduct and bummper. (not sure about varis one...)
which one looks better in person? (like cf pettern and fit ment stuff and finish..)
Old Mar 29, 2007 | 12:28 PM
Fluid1's Avatar
Fluid1
Titek is cheaper. They don't look any different, from the pictures.
Did you seriously say that one has better air flow? lol
Old Mar 29, 2007 | 01:50 PM
97supratt's Avatar
97supratt
They both look about the same but the exit diameter of the varis is bigger (the hole feeding into the intake).
Old Mar 29, 2007 | 03:11 PM
Track's Avatar
Track
Yes it is. The angle of the cut on the headlight side is also different. I have read here that the varis has lines that follow the angle of the headlights, while the other does not. The varies does have a larger intake nacel.
I've also seen tubing that connects the varis directly to the factory intake. I do not know, however, if this is included. I believe that is extra and I've even seen one made of carbon fiber.
Hope that helps. I'm researching all this stuff right along with ya and just passing on what I've learned in the last couple of weeks about these things.
Old Mar 29, 2007 | 03:14 PM
Fluid1's Avatar
Fluid1
I totally believe that. I was more referring to the overall benefit of it, like how much hp different could it possibly be. Also, if the exit diameter is bigger on the varis, couldn't you also file (or dremel or whatever) the Titek down some to open it more, if that's the biggest issue?
I can also see the argument that Varis is a bigger/better name, like Megan BBK vs. others.
Old Mar 29, 2007 | 03:15 PM
Fluid1's Avatar
Fluid1
Good info, thanks for sharing your research.
Old Mar 29, 2007 | 05:57 PM
tomiegunzz's Avatar
tomiegunzz
Varis = 0 hp Titek = 0 hp
Old Mar 29, 2007 | 06:26 PM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
im sure you get some benefit out of it when your moving, and not just sitting on a dyno.
Old Mar 29, 2007 | 07:37 PM
TurboTrey's Avatar
TurboTrey
Can anyone justify why these parts cost $100? It looks to me like it is a few pieces of plastic. I've been wanting an intake but the popcharger just looks like a regular cone filter with a heat shield. Isn't that like $20 and a few minutes of fabbing at Pep Boys?
Old Mar 29, 2007 | 07:41 PM
MustGoFastR's Avatar
MustGoFastR
It is not included. Evo-R makes them. They are made of fiberglass.
Old Mar 30, 2007 | 06:05 AM
THE TECH's Avatar
THE TECH
Varis FTW.
Old Mar 30, 2007 | 06:11 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I went with the Autotecknic and love it. Pretty much the same as the Varis but a lot cheaper and w/o the wait. Just had to add some 1500* clear coat on the underside. I've read that the CF turns yellow from the heat.
PIC:
http://i107.photobucket.com/albums/m...ullShroud1.jpg
Also you can link to their site in my sig. Bought mine from there E-Bay store.
EDIT: OK I'm a dumbass! I don't know why I was thinking the CF Shroud. As far as the front bumper Airduct... Varis!
Old Mar 30, 2007 | 08:24 AM
97supratt's Avatar
97supratt
Actually there was a article done on these ram air devices on sport bikes and they showed hp gain but at 120+mph.
Old Mar 30, 2007 | 08:43 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Well I've been known to get to 120 every now and than. I'm sure the cooler air getting to a short air intake helps. Not expecting 5,10,15hp but a cooler engine is a cooler running engine.
Old Mar 30, 2007 | 07:17 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Varis in stock (shameless plug) - see our ad in the classifieds at the link below
Vivid Racing
Apr 30, 2008 06:02 AM
Z350Lover
Australia/New Zealand
Mar 1, 2004 11:53 AM
