Dash Rattle???
Old Apr 14, 2007 | 03:21 PM
g0tb00st's Avatar
g0tb00st
Default Dash Rattle???
I finally found the rattle that's been annoying me. I first thought it was my hatch, now I realize it's coming from my dash on the passenger side. Anyone else have this issue and what's the fix for it? The rattle sounds like a loose screw vibrating against metal. It's very annoying!
Old Apr 14, 2007 | 07:33 PM
jrforrester's Avatar
jrforrester
i have it as well - mine is an 03... my solution has always been to just turn the music up louder.. I think its just a poor fitment issue, not necessarily a screw.. I've also taken my dash apart though many times, so it's probably my fault, haha..
Ever taken yours apart?
Old Apr 14, 2007 | 08:30 PM
DVFlyer's Avatar
DVFlyer
Speed of White
I have a rattle on the driver's side of my '05. I'm looking for instructions on how to take the dash off so I can find the rattle and see about mounting speakers up there.
Old Apr 15, 2007 | 04:42 AM
g0tb00st's Avatar
g0tb00st
mine is an 03' 6spd touring. i couldn't find instructions on how to take the dash apart. (got a link?) I'm really sick of having to turn up the music to make the rattle go away!
Old Apr 15, 2007 | 05:39 AM
MarkM's Avatar
MarkM
The noise on mine was cured by adding a little spacer between the dash and screen, it was actually rubbing there. Just beyond the screen demister vent is right where I put it....silent now
Old Apr 15, 2007 | 08:08 AM
Track's Avatar
Track
"Screen?"
Old Apr 16, 2007 | 02:55 AM
g0tb00st's Avatar
g0tb00st
do you mean front windshield?
Old Apr 16, 2007 | 10:21 AM
MarkM's Avatar
MarkM
Yes, sometimes I forget I'm a foreigner
Old Apr 16, 2007 | 04:29 PM
g0tb00st's Avatar
g0tb00st
would you be so kind as to take a picture of where you put the spacer? i'm sure it would help a ton of people here.
Old Apr 16, 2007 | 04:41 PM
skwid's Avatar
skwid
Pull the Dash Off and check the knee plate. That's probably your problem.
Old Apr 16, 2007 | 06:22 PM
g0tb00st's Avatar
g0tb00st
got instructions on how to pull the dash? also, what the knee plate?
Old Apr 16, 2007 | 10:11 PM
Track's Avatar
Track
Wtf is a "knee plate?"
Old Apr 17, 2007 | 04:41 AM
skwid's Avatar
skwid
I have no idea it just sounded cool.
Anyway do some searching. You can find the dash panel removal instructions. I had a crazy annoying dash rattle when mine was brand new and I pulled the passenger lower dash off and poked around until I found what was causing the rattle. I adjusted it and never rattled since.
Old Apr 17, 2007 | 06:55 AM
davidz33's Avatar
davidz33
I have 06 and mine's coming from the steering wheel column.
Old Apr 17, 2007 | 07:42 AM
DVFlyer's Avatar
DVFlyer
Speed of White
The knee plate probably means the knee pad on the sides of the vertical center column.....
Re: instructions- I've seen the ones on how to take apart the console. I'm looking for any info on how to take apart the REST of the dash.
Old Apr 17, 2007 | 08:50 AM
Track's Avatar
Track
What was making the rattle? Was it an airbag thing or something?
Old Apr 17, 2007 | 10:00 AM
bbs350z's Avatar
bbs350z
the dash is easy 2 take off, assuming the center console. that, pull the shifter surround up and off (after the **** of course, and theres screws, unscrew them, and unclip all the wiring harness, and pull gently. as 4 the dashboard, there r clips. take out the cup holder, and a couple screws down on the lower part and gently tug, 2 unclip (as if ur getting to ur ecu)
Old Nov 11, 2008 | 11:50 AM
350Zenophile's Avatar
350Zenophile
I made a DIY for this if anyone still has the rattle:
https://my350z.com/forum/body-interi...le-squeak.html
jlb
Oct 15, 2017 05:10 AM
Vigman
Nov 17, 2015 04:34 AM
Ryan Bonner
350Z Roadster
Sep 8, 2015 04:16 AM
