In Big Trouble-need Help Badly
I have foglamps installed on my '06 MT, which are wired to my side market lights.
So I desided to up my bulbs to 100W from 55w because the 55's were not bright enough. I changed the bulbs, flicked the switch and all the running lights blew went off. All the other lights...stop, turn signal, 4-way flashers, and headlights work fine...just the running lights don't burn.
I've checked the fuses in the J/B fuse box near the drivers door, and all are good. There are other fuses that show on the Power Supply Routing Circuit schematic like fuse #71 which controls the tail lamp relay, but I can't figure out where those fuses are.
Can someone give me a hand. Without those lights, I can't drive at night. I can't belive this is happening. All the dealer wants to do is have me bring it in so that they can run a diagnostic on it...but I know it is just a blown fuse, just can't figure out where this fuse #71 is located.
Thanks for any help that you guys can give me.
Originally Posted by Chebosto
the other set of fuses are in the engine bay, next to the battery...
hope you didnt blow your HID balasts.. or fried a relay..
The one I am talking about is the one right before the tail lamp relay, a10 amp in fuse location #71.
The HID's work fine. This one has me stumped.
Thanks for your help anyway.
