Newer AC knobs swap...
Old Apr 20, 2007 | 02:15 AM
halfass872's Avatar
halfass872
Default Newer AC ***** swap...
Has anyone put the new style AC controls, or ***** in an older Z ( '03 for instance ) Or does anyone know if this will work? I.E. Plug and play?? Thanks!
Old Apr 20, 2007 | 04:45 AM
davidf's Avatar
davidf
I have been told no.
Old Apr 20, 2007 | 05:52 AM
THE TECH's Avatar
THE TECH
Give it a try and let us know.
Old May 19, 2007 | 06:18 AM
CRAZY Z's Avatar
CRAZY Z
I've been working on this couple of months and can not get it to work. I have bought two 06 ac ***** and tried everything to get to work, even resoldier everythig to the old board. Now, I am looking for 06 ac control unit that sits right below the ***** in the center dash (white box). So, I can try some more stuff witht his project...If you know anyone with 06 ac control, send them my way!
CRAZY Z
Old May 19, 2007 | 09:04 AM
THE TECH's Avatar
THE TECH
I'd say that if you had the a/c box and **** panel that it might just plug in.
Old May 21, 2007 | 07:49 PM
CRAZY Z's Avatar
CRAZY Z
Yah, it works if you install a new ac controller from 06-07.
Old May 21, 2007 | 07:50 PM
THE TECH's Avatar
THE TECH
Is that a guess or have you actually done it?
Old May 22, 2007 | 08:46 AM
CRAZY Z's Avatar
CRAZY Z
I did it yesterday. I have another thread that talks about all this. "2003 to 2006 interior swap". I am going take some pics later and post.
Old May 22, 2007 | 08:59 AM
bbs350z's Avatar
bbs350z
so will the 03 control ***** work w/ an 06 dash??
and if i were to do this i would need the entire console+a *****+the white control box?
Old May 22, 2007 | 09:18 AM
z350boy's Avatar
z350boy
Why would you want to do this mod??? The pre 2006 ***** look MUCH BETTER IMHO.
Old May 22, 2007 | 09:41 AM
CRAZY Z's Avatar
CRAZY Z
Yes you would need the upper center console, shifter console, center console, ac *****, and ac controller.
Old May 22, 2007 | 09:43 AM
THE TECH's Avatar
THE TECH
Did you try putting the **** section on the 03 console?
Old May 22, 2007 | 01:39 PM
CRAZY Z's Avatar
CRAZY Z
Yes, doesn't work. 03 ***** base is bigger and will not fit through the holes. I tired everything.
Old May 22, 2007 | 01:41 PM
THE TECH's Avatar
THE TECH
So there's really no point in this unless you plan on changing out the entire dash since none of the older stuff matches up to the newer stuff.
sherm
Apr 11, 2020 05:21 PM
FromGtoZ
Sep 20, 2015 03:41 PM
etong
Sep 10, 2015 06:14 PM
