what can you do to repair faded cf hoods?
Old Apr 29, 2007 | 08:39 PM
gimpster621's Avatar
gimpster621
Default what can you do to repair faded cf hoods?
my oem seibon is starting to fade to like a carbon kevlar color lol. anyway i can repair this myself?
Old Apr 29, 2007 | 08:40 PM
VN_350z's Avatar
VN_350z
Get a new one. No cure
Old Apr 29, 2007 | 10:51 PM
702Fairlady's Avatar
702Fairlady
Body shop here in vegas redid an Evo wing. They might be able to redo your hood. I would call and ask some body shops. If mine can do it, you might be able to give the hood to my brother to bring down here.
Old Apr 29, 2007 | 10:54 PM
groovin_350z's Avatar
groovin_350z
Sleeps in 350Z
there's shops that can clean it up for you depending how bad it is. i've had friends either have a shop re buff the thing out if they can or have them re clear coat it
Old Apr 30, 2007 | 06:44 AM
gimpster621
yea ive been reading on on it and said cf hoods are gel coated to wax is not good. ive been reading up on some marine 3m stuff but i was hoping someone who had the same experience could chime in here
Old Apr 30, 2007 | 06:47 AM
bb1314's Avatar
bb1314
da Terminator!
What about painting it?
Old Apr 30, 2007 | 06:58 AM
MyFaiRLaDy's Avatar
MyFaiRLaDy
i had the same problem where my overcoat was all dulled out due to the sun on my fiberimages hood. Where i had like a turtle shell imprint on it, so i took it to my paint guy and he wet sanded it and applied a layer of clear coat on it. Looks brand new!!!
Old Apr 30, 2007 | 07:04 AM
THE TECH's Avatar
THE TECH
Strip and re-clear is the only way I know of.
Old Apr 30, 2007 | 07:07 AM
tonester1011's Avatar
tonester1011
CF God
+1 for reclearing...i think i am going to try that on my seibon
Old Apr 30, 2007 | 07:23 AM
gimpster621
yea probably the best way to go. damn i shoulda done it while it was in the shop couple weeks ago
Old Apr 30, 2007 | 07:45 AM
Armitage's Avatar
Armitage
Yeah just have them re-clear it.
Old Apr 30, 2007 | 08:53 AM
nzpv03's Avatar
nzpv03
how much does re-clearing usually cost on average? thanks
Old Apr 30, 2007 | 11:01 AM
benDF's Avatar
benDF
The problem usually occurs from either low grade resin being used when manufacturing the parts and/or a lack of UV protection.
"Yellowing" of lower grade hoods is common, and not "fixable". You can cover it up, by reclearing the hood with a darker clear. That is about all you can do as far as I know.
One way to prevent this from happening is to clear coat the hood when you get it. Make sure the clear coat has UV protection. Or, buy a hood from a company that has UV protection in their gelcoat...
Old Apr 30, 2007 | 11:26 AM
Jim@Showstoppers's Avatar
Jim@Showstoppers
Seibon uses UV gelcoat.
How long have you had the hood Gimpster? Is it a hazy fade (as in the clear) or the carbon fiber itself it turning "yellow"?
gimpster621
so i should specify and ask for a uv protected clear coat?
Jim@Showstoppers
I've seen between $50-$150.
Old Apr 30, 2007 | 01:12 PM
benDF's Avatar
benDF
It can also be the resin they are using. Raw materials have many levels of quality. Regardless, a carbon fiber part turning yellow is not a good sign.
Most of manufacturers I have worked with/at use a UV gelcoat(specifically formulated to be used with carbon fiber) + UV clearcoat. Obviously, quality of the materials play a big part in the final product.
Old May 6, 2007 | 12:44 AM
Cannysage's Avatar
Cannysage
how long would it take to go dull? I'm thinking about purchasing a seibon, and thought of clear coating, but prolly leave it till it gets dull and re clearcoat.
Old May 6, 2007 | 07:55 AM
Jim@Showstoppers
Depends on how you take care of it. If you wax it regularly and don't let it sit baking in the sun for extended periods of time, it can be years before a new clear coat would be needed.
BEBO'S ZEE
Jun 7, 2016 07:48 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
EnjukuRacing
Misc.
Sep 23, 2015 07:27 AM
Wu-Watt
East Canada
Sep 12, 2015 07:31 AM
issyz
Sep 10, 2015 02:00 PM
