AeroCatch hood guard question
Old May 17, 2007 | 06:11 AM
ZlleH's Avatar
ZlleH
Default AeroCatch hood guard question
For anyone that has the AeroCatch hood guard on their hood.
Did all of you used the red studs that came with the AeroCatch package? I heard the studs are larger then the default hole that the 350Z has and you have to make the hole larger for the studs to screw in.
Did any of you use another comapnay's stud with your AeroCatch setup? I heard the Sparco studs screws in perfectly to the 350Z's default hole.
Thanks.
Old May 17, 2007 | 07:16 AM
THE TECH's Avatar
THE TECH
The studs that come with it will work fine.
Old May 17, 2007 | 07:24 AM
DJShan209's Avatar
DJShan209
+1
Old May 17, 2007 | 09:44 AM
IIQuickSilverII's Avatar
IIQuickSilverII
http://www.intensepower.com/aehopinlasy.html
good call on those and the studs work fine btw
Old May 17, 2007 | 11:20 AM
ZlleH's Avatar
ZlleH
Okay, the "stud works fine" comment... meaning that you do not have to make the default holes in the 350Z larger to screw them in? You can just screw in the red studs wihtout doing anything to the holes in the 350Z?
Old May 17, 2007 | 11:39 AM
IIQuickSilverII
this shoudl give you a good idea
PM me if you need more help
issyz
Jul 2, 2017 03:04 PM
Mattg350z
Oct 2, 2015 06:51 AM
