Which hood pins to buy for Seibon CF Hood?
Old Jun 22, 2007 | 08:24 AM
Jim@Showstoppers's Avatar
Jim@Showstoppers
Yep, use a dremel and sharp bit to avoid cracking.
Jim
Old Jun 22, 2007 | 08:38 AM
mdracer76's Avatar
mdracer76
+1 on dremmel.
I run the Sparco's myself. like them allot. inexpesive, and a race proven piece of hardware.
Old Jun 22, 2007 | 08:51 AM
myehrick09's Avatar
myehrick09
Originally Posted by Chebosto
put newspaper over your engine to prevent fiberglass/carbon from getting in. its nasty. wear long sleeves and avoid contact with bareskin, else it's itchville for you.
for the bottom of the hood- mark top of hood pin with glitter glue/whiteout/grease pen and xfer the center point to the underside of the hood-
drill a pilot hole then use a 1" hole cutting bit. remember, the hood swings up so tthe hole you make will have to be large enough to accomodate for the swing-
remark the top of the hood pin again and then close the hood- drill a pilot hole on the bottom of the carbon layer. then go from the top and depending on the orientation of your hood pins, go with a progressively larger pit on high speed.
you might need to elongate the actual hood pin's opening due to the curvature of the hood and where the pin goes through.
repeat to other side and then do minor adjustments as necessary. its really simple. just dont rush it.
Kewl. what about the screws for the sparco pins that cathces the pins, can I just drill this straight to the head or do I have to pre-drill it?
Old Jun 22, 2007 | 09:07 AM
synth19's Avatar
synth19
My vote goes for the Aerocatch flush latches. Same product as the one pictured, without the top secret JDM price.
Old Jun 22, 2007 | 09:08 AM
UrbanTacticZ's Avatar
UrbanTacticZ
I would say predrill, it is how you avoid cracking
Old Jun 22, 2007 | 10:33 AM
Chebosto's Avatar
Chebosto
i would opt to pre-drill small holes then use rivets instead of the screws if thats what you want to do..
or 3m double stick all weather tape it. - thats what i did..
Old Jun 22, 2007 | 03:32 PM
sibble's Avatar
sibble
+1 dremel
ive cut CF with my dremel before, worked excellent. like the_tech said, the faster the better
Old Jun 22, 2007 | 05:21 PM
lovetoclown's Avatar
lovetoclown
Dremel all the way. If you stairstep your drill bits, you have a great risk if cracking or chipping. the dremel made all the work easy.
Old Jun 22, 2007 | 05:36 PM
Crom's Avatar
Crom
make sure your measurements account for both layers of the hood since it closes in an angular fashion...thats where I messed up. Also Hayame makes some gunmetal sparco clones that I bought that are pretty cool.
Old Jun 22, 2007 | 05:53 PM
boostedef's Avatar
boostedef
AeroCatch FTMFW
Justin100
Nov 25, 2021 06:26 AM
Alexreyes
Sep 30, 2015 11:30 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
