my ghetto hoodpin (pic)
Old Aug 20, 2007 | 06:54 PM
05-Z's Avatar
05-Z
Default my ghetto hoodpin (pic)
I've been reluctant to use hood pins for many reasons...most don't look that well and can be a PITA to use. I like the aerosnyc style, but don't want huge holes in my hood. I randomly thought of this idea and decided what the hell, it can only help....
After spending some $$ on a custom paint job for my latest hood, and a few high speed runs, I noticed my hood would sometimes "float" despite everything being tightened down. Not good for confidence.
Anyways, I bought this cable and drilled a hidden hole into the chassis of the car, and attached a quick release clip that clips onto the hood latch. They use these cables to support tailgates on pickups, it's strong as hell. It's ghetto, but it's better than nothing.
Old Aug 20, 2007 | 08:18 PM
Risky_Business's Avatar
Risky_Business
Quadrant 987c
Default I've said it once and I'll say it again...
it's not ghetto unless it's covered in diamonds and spins...
Old Aug 20, 2007 | 09:22 PM
ZlleH's Avatar
ZlleH
If you find your hood "floating" may I suggest you put weather stripping to the bottom front of your hood so you can stop the wind from going into that little slit in the front?
Old Aug 21, 2007 | 04:43 AM
synth19's Avatar
synth19
good idea, I have this with my hood. Pics later.
Old Aug 21, 2007 | 04:44 AM
synth19's Avatar
synth19
05-Z , let's see pics with it installed.
Old Aug 21, 2007 | 06:27 AM
05-Z's Avatar
05-Z
I'll post pics this weekend....I suppose a picture is worth a thousand words.
The clip attaches next to the latch on the hood, so in the event the hood latch releases or cracks, the strap is still connected.
Old Aug 21, 2007 | 06:43 AM
synth19's Avatar
synth19
^ but what happens if the latch completes breaks?
Old Aug 21, 2007 | 06:49 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
Would have to see pics, but it seems like this is only going to prevent the hood from completely opening. The hood may still break in the middle and flying into the windshield.
If the latch gives at high speeds, the hood will fly up and the cables will hopefully hold, but at that point youve got alot of wind going under the hood which could cause failure.
IMO, go real hood pins. There rigid and hold the hood down/closed. Cables will let it open, not good.
Old Aug 21, 2007 | 06:56 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I'll take that hood off your hands if you want +1 on pics...
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Nov 9, 2015 11:10 AM
Fixxxercask
Cooling System
Nov 5, 2015 03:21 AM
Tochigi_236
Sep 27, 2015 03:40 PM
