Interior 'Map' Lights
Old May 16, 2003 | 11:40 AM
phreezee's Avatar
phreezee
Default Interior 'Map' Lights
Can anyone tell me what bulbs these are? I wanted to swap them out for the leds on http://www.superbrightleds.com
Or better yet... which one of these would fit?
1)
3022 White LED Festoon Base Bulb
31x10mm 12 VDC
Available with 2 or 4 LEDS aiming in the same direction
$ 2.45
2)
1142 White LED Festoon bulb
42x11mm 12 VDC Festoon Base Bulb with 6 Super White LEDS
$ 3.49
3)
Neither
Thanks in advance.
Old May 16, 2003 | 03:54 PM
Ricky's Avatar
Ricky
Don't remember off hand the sizes, but it does tell you in the manual, check the index under "Bulb" =)
Old Sep 22, 2003 | 09:20 PM
LeMansZCa's Avatar
LeMansZCa
can you "just" swap out the light bulb with the led's? or u need resistors??
if were able to swap out the bulb, could you pls let us know which led? thanks!
I would love to have some led's for the map light!
Old Sep 23, 2003 | 11:37 AM
jesfuego's Avatar
jesfuego
The bulb number is the t-6 I swaped mine out for the PIAA xtream white, I actually bought them at sound advice. they made a world of a diffrence. good luck!
Old Sep 23, 2003 | 01:16 PM
DIGItonium's Avatar
DIGItonium
Yes, you need resistors to prevent overpowering the LEDs.
I'm currently selling my Luxeon dome lights. They've been in my car since day 1, and still lights up nicely.
I'm going to replace them with this year's production Luxeons because of improved color rendering.
They look a tad yellow, but the light emitted is very neutral and easy on the eyes at night. I just want a whiter look.
Here's a picture of what this coloration looks like.
Old Sep 23, 2003 | 01:26 PM
ares's Avatar
ares
Veteran
I believe the ones on superbright LEDs have build in resistors as they are made for a specific application and current.
loose LEDs that they also sell, or luxeon, do require resistors as well as a bit extra work, they arent made to plug in, if your not familiar Id go with the regular premade set, or the ones from DJ since they are already setup.
Old Sep 23, 2003 | 08:11 PM
DIGItonium's Avatar
DIGItonium
Default 8-O
Wah? Can I be MY350Z Inventor?
Or MY350Z DJ?
:-D
-Once I find the materials, I'll figure something out. Now I got 4 tests to study for next week. Anyone enjoy Thermodynamics?
Old Sep 23, 2003 | 08:35 PM
ares's Avatar
ares
Veteran
absolutely not, right now Im prefering aromatic reactions at 11 and transcription at 12, followed by Im not sure what at 1.
I did my thermodynamics 2 years ago, Ill never go back, NEVARR!!!!!
Old Sep 23, 2003 | 09:24 PM
LeMansZCa's Avatar
LeMansZCa
do you know is there a superbright LED that can just fit into the map light? any part number would be highly appreciated.
Old Sep 24, 2003 | 07:14 AM
ares's Avatar
ares
Veteran
not "just an led" they always just have 2 contacts, no actual peice.
but I believe superbrightleds makes them with a plug peice already assembled to plug right in, and I guess piaa does as well.
Old Sep 24, 2003 | 12:41 PM
DIGItonium's Avatar
DIGItonium
Heh... we all took a quiz today, and I didn't know anyone who could finish the problem.
Anyhow... can i still be inventor? :-D AHAH... or DJ... it would be fine.
*Currently talking to someone about getting plastic bulb pieces.
*I think I found a good place for resistors... maybe zener diodes as well!
Uriyo_
Sep 8, 2021 08:46 AM
HoBrahYouStink
Jun 24, 2016 10:58 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
