LEDs: Turn signal & running - pics
Old May 16, 2003 | 05:50 PM
POWERZ's Avatar
POWERZ
Post LEDs: Turn signal & running - pics
I just installed LED cluster lights in the front and rear turn signals and single LEDs in the running lights. I bought them here.
Attached Thumbnails LEDs: Turn signal & running  - pics-leds.jpg
Old May 16, 2003 | 05:51 PM
POWERZ's Avatar
POWERZ
Front turn signal
Attached Thumbnails LEDs: Turn signal & running  - pics-front-signal-lit.jpg
Old May 16, 2003 | 05:52 PM
POWERZ's Avatar
POWERZ
Rear turn signal
Attached Thumbnails LEDs: Turn signal & running  - pics-tail-signal-lit.jpg
Old May 16, 2003 | 06:00 PM
POWERZ's Avatar
POWERZ
I'm really happy with them - they look a lot better than the solid orange bulb. My only complaint is that the base of the light is yellow tinted plastic instead of clear.
Attached Thumbnails LEDs: Turn signal & running  - pics-rear-signal-close.jpg
Old May 16, 2003 | 06:22 PM
POWERZ's Avatar
POWERZ
Running lights and headlights
Attached Thumbnails LEDs: Turn signal & running  - pics-headlight-lit.jpg
Old May 23, 2003 | 08:49 AM
POWERZ's Avatar
POWERZ
I found other colors here.
Attached Thumbnails LEDs: Turn signal & running  - pics-leds.gif
Old May 23, 2003 | 11:58 AM
POWERZ's Avatar
POWERZ
These are just white. They do have a more blue-ish tint than the HIDs. I took out the fender-well to access the lights.
Attached Thumbnails LEDs: Turn signal & running  - pics-running-front.jpg
Old May 24, 2003 | 09:31 PM
ares's Avatar
ares
Veteran
needs more light you say?
dum de dum de dum...
Old May 24, 2003 | 09:57 PM
ares's Avatar
ares
Veteran
gotta wait till I finish the prototype tail light, but thats next, more light in there should be a cake walk compared to the tail light.
Old Jun 25, 2003 | 03:23 AM
ZEXC-33's Avatar
ZEXC-33
Dude im a bit confused. Which LEDs did u replace the parkers (running lights) with??? Could u please tell me the LED type, color and the site u bought them from. They look great!!!
Old Jun 25, 2003 | 04:51 AM
POWERZ's Avatar
POWERZ
No problem. Check out my very first post in this thread. It shows a pic of the leds as well as a link to the site I bought them from.
(194, white, superbrightleds.com)
Old Jun 25, 2003 | 06:30 AM
junglist350Z's Avatar
junglist350Z
so the rear signals are 7443 bulbs right? did the yellow ones you bought light up orange?
Old Jun 25, 2003 | 06:54 AM
POWERZ's Avatar
POWERZ
Yep, 7440 or 7443 for both front and rear signals. Mine light up orange - see above pics.
Old Jun 25, 2003 | 07:03 AM
junglist350Z
i tried 7440 and couldnt get them to fit in the rear, 7440 fit fine in the front
Old Jun 25, 2003 | 07:54 AM
old_s13's Avatar
old_s13
I dont mean to burst your bubble, but those plug-in LED replacements are not really adequate enough for street use and could get you in a bit of legal trouble should your car be involved in an accident. Those LED clusters emit less light than stock and do not have a wide enough viewing angle. Its very important that the Z33 front and rear signals are visible from a multitude of angles.
- Mike
Old Jun 25, 2003 | 06:09 PM
sean6tt's Avatar
sean6tt
powerz:
how did you remove the rear turn signal to put the new bulbs in...
thanks
sean6tt
Old Jun 25, 2003 | 06:32 PM
POWERZ's Avatar
POWERZ
Originally posted by sean6tt
powerz:
thanks
sean6tt
Pop off the tail light (3 bolts on top - more info in owners manual) and you can reach the rear signals fairly easily.
Old Jun 25, 2003 | 10:02 PM
frenzee's Avatar
frenzee
Originally posted by old_s13
...LED replacements are not really adequate enough for street use...
Just curious if anyone had noticed that the municipal buses, at least here in SoCal, use LED brake, tail and turn signal lights and they are SPANKING bright. I was following one this morning and it seemed like there were only about a dozen or so LED elements in each light, althought the housing itself was fairly large, maybe 6" or 8" in diameter. Hey Ares, you're the expert on this. Couldn't that same type of LED element be used to make a compact "bulb" replacement that is as bright as the oem one?
Old Jul 18, 2003 | 11:22 PM
dreamznblu's Avatar
dreamznblu
Default Parking Lights
Those parking lights are sweet, and $1.50 each, definately worth the price
Old Aug 12, 2003 | 07:38 AM
POWERZ's Avatar
POWERZ
- Mike
You are right, Mike. After having them installed for a couple of months I have realized that the turn signals are not bright enough during the day, especially from the side. Another unfortunate side affect is that the blinker flashes twice as fast, presumable due to a difference in resistance. Good for show, but a liability on the street.
No complaints with the parking lights though!
