LEDs: Turn signal & running - pics
Old Aug 12, 2003 | 10:06 AM
ares's Avatar
ares
Veteran
Originally posted by frenzee
Just curious if anyone had noticed that the municipal buses, at least here in SoCal, use LED brake, tail and turn signal lights and they are SPANKING bright. I was following one this morning and it seemed like there were only about a dozen or so LED elements in each light, althought the housing itself was fairly large, maybe 6" or 8" in diameter. Hey Ares, you're the expert on this. Couldn't that same type of LED element be used to make a compact "bulb" replacement that is as bright as the oem one?
expensive enough LEDs can do incredable things. it really is a matter of how deep your pocket is at a certain point.
they can give off light. but tho that company sells very very bright LEDs they are very narrow angle of output. for some applications I personally dont think thats a problem, such as reflectors where you want the light to go out. but if you have a case like the turn signal or something, you need it to shoot all over.
they can be bright. all in how you do it I suppose.
Attached Thumbnails LEDs: Turn signal & running  - pics-im001457.jpg
Old Aug 12, 2003 | 10:12 AM
ares's Avatar
ares
Veteran
oh also, the reason there are no problems with using LEDs in the sidemarkers for turnsignals is because the lightbulb load is still there. thats what it needs. for those replacing that, check that company, they sell a 6ohm 50watt resistor for 5$. wire that in and the car wont know the bulb isnt there, no more hyper flashing or anything.
Old Aug 12, 2003 | 01:43 PM
LowUFO's Avatar
LowUFO
Ares,
How would you wire in the 6ohm 50watt resistor? In series, or parallel?
Ian
Old Aug 12, 2003 | 03:07 PM
ares's Avatar
ares
Veteran
Id imagine in series... but dont quote me on that.
Old Aug 12, 2003 | 03:43 PM
DMONTE's Avatar
DMONTE
Originally posted by POWERZ
These are just white. . I took out the fender-well to access the lights.
I bought a set of these LED lights A few months ago and was not able to fit them into the tube like socket maybe they were A different brand, did you have any problem?
Old Aug 12, 2003 | 04:35 PM
ares's Avatar
ares
Veteran
Im changing my mind, I think it should be in parralel. Id imagine there would be instructions for it tho.
dmonte-are you sure you got the right size?
Old Aug 12, 2003 | 04:39 PM
DMONTE's Avatar
DMONTE
I purchased them a while back off of eBay, I also purchased chrome amber turn singles that I actually had to file down slightly to fit. It looks like I will have to do the same thing with the marker lights they look just like the ones shown in the photo but they're just slightly to large. But very good quality actually the best chrome turn singles I have seen so far.
Old Aug 12, 2003 | 04:46 PM
ares's Avatar
ares
Veteran
were they phillips or APC? I here the APC one heat and melt off, *crap*.
but the phillips are very good.
Old Aug 12, 2003 | 05:03 PM
DMONTE's Avatar
DMONTE
The following link is for the chrome bulbs
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2427200215
The next link is the LEDs that I'm having trouble fitting into the socket.
http://cgi.ebay.com/ws/eBayISAPI.dll...1&category=371
Old Aug 12, 2003 | 05:26 PM
ares's Avatar
ares
Veteran
those LEDs are probably better left out of the socket... a single LED? LEDs are very efficient, but not very powerful by themself. youd need a dozen or so to even dream of reaching the brightness of a bulb.
Id leave that out, gonna look like a christmas tree light in there
Old Aug 12, 2003 | 05:35 PM
DMONTE's Avatar
DMONTE
A Christmas tree light that's pretty good
Those chrome turn signals are from Japan did not have a brand on them, I have had them for six months now and they're working fine and nothing has melted off its just a very light chrome plating like a two-way Meera and about 60 to 70% of the brightness when light in amber but because of all the chrome reflecting in the front headlights it seems to be fine I just used them on the front and decided not to replace the rear one's because of safety issues I would rather have them full brightness.
Old Aug 12, 2003 | 05:39 PM
ares's Avatar
ares
Veteran
yeah definitly not APC(american products company) if there from japan:P
not sure who theyd be, but if they lasted this long, cant be too bad.
Old Aug 12, 2003 | 11:29 PM
sifuK's Avatar
sifuK
look 5 bucks
http://shop.autoi.com/osb/itemdetails.cfm/ID/3565
Old Aug 13, 2003 | 04:46 AM
POWERZ's Avatar
POWERZ
DMONTE - not sure why you are having problems fitting the lights in. I actually wished that the opening for the lamps was smaller for a cleaner presentation!
Christmas tree light? Yeah, I suppose it is a bit out of place. But I don't think making it brighter would help out too much. The real problem is the stock yellow color contrasting with the HIDs, and any type of white LED will fix that up nicely.
Old Aug 13, 2003 | 06:15 AM
DMONTE's Avatar
DMONTE
[QUOTE]Originally posted by POWERZ
[B]DMONTE - not sure why you are having problems fitting the lights in. I actually wished that the opening for the lamps was smaller for a cleaner presentation!
I don't mean the opening where the single white LCD passes through the chrome headlight housing, I mean where you actually plugged the LCD into the black socket tube type harness is way too tight. Was yours also tight for you?
Old Aug 13, 2003 | 06:21 AM
POWERZ's Avatar
POWERZ
[QUOTE]Originally posted by DMONTE
Sorry, I was confused. Yes, the bulbs all fit very tightly. I didn't have to shave any plastic but it did take a bit of persuasion.
Old Aug 13, 2003 | 06:24 AM
DMONTE's Avatar
DMONTE
Do you find those particular bulbs to be bright enough?
Old Aug 13, 2003 | 06:39 AM
  #38
POWERZ's Avatar
POWERZ
Yep, I'm happy with the running lights. They could be brighter, but my main compaint was with the color. I didn't want something that would take away from the HIDs, just something with better color. I know they make 2 and 4 led bulbs in that size if you are looking for brightness.
apex locator
Jul 23, 2021 02:27 AM
350Z_Al
Oct 29, 2020 07:44 PM
