Damaged CF Lip!!
What todo next
i am going the route of repairing it then painting it. My choose is Black and leave my airduct and rear spoiler CF, or paint it PPW and paint all the CF the PPW. I will be painting it myself since my money is tight this year. I have all the tools to paint it, just need to get the PPW.
Here is a full un damaged picture:
Originally Posted by THE TECH
This is the reason I suggest to all my customers not to buy CF pieces for the front of the car. One crack and it's done.
Ill be able to fix it, just not sure witch way to go with paint. Black or PPW. if i do black all ill paint is the lip. If i go with PPW then ill want to paint all my CF that.
Originally Posted by NA&CH
Paint that area PPW and leave the center CF. Should look good.
Chris
Chris
Originally Posted by Nexx
i agree 100%, i still want a black lip look so im switching my attention to black gel coated reinforced fiberglass or black urethane.
Another thought is that although fiberglass parts break instead of bending, it is much easier to repair fiberglass than to repair urethane. Urethane will bend but it will also tear, and short of melting/stretching material back into place there is no great way to repair it. Although I do think that urethane would be a better pick for the front end, because you would have to hit something pretty hard to tear a hole in the front lip.
Originally Posted by drift_projekt_Z
on the lip i would paint the sides, leave the center cf. and leave the middle of the wing cf/ looks clean btw.
i notice you have sportmax rims. how those holdin up?
Im still debating weather to the sides PPW center CF or just all Black.
Editing:
Well i desided to go black. I think it will look better then part ppw and part cf. Plus then i dont have to paint the other part ppw
Oh and i looked closer to the damages, it sliced the bottom from the hole to the back, so the underside will need a splint.
I started surgery today on the damaged spot. Im trasforming it into the bionic Lip, faster, stronger and be able lep over other cars LOL j/k
I got the splint fastened, let just say its not coming off
I got the hole patched and i in-filled just a little higher then the rest of the lip. Earier to sand down and fit the contouers. Tomorrow is sanding day. Ill take picture tomorrow after sanding.
Originally Posted by james840a
Yep, my rims are holding up pretty good, i have had them on for a year now with no troubles.
Editing:
Editing:
Originally Posted by Jay'Z
Looks like he ran into a curb.. Or smacked into something..
Originally Posted by sluggoZ
Go with black...PPW is going to be very, very hard to match!
Just the typical garbage on the Fwy, ran over a peace of metal. Was unavoidable
