Xenon to hallogen headlights
Old Sep 5, 2007 | 06:27 PM
JYP's Avatar
JYP
Default Xenon to hallogen headlights
Hey Guys,
I am new to this forum. I have a 350Z from 2005 (touring fully loaded) that I bought in the USA and that I would like to bring back to Europe (Switzerland).
Apparently, the legislation is very strict with Xenon headlights and I would need to make modifications worth 3000-4000 dollars!!!
I was wondering if you knew if it was possible to replace the xenons by hallogens (as some 2003 models had). This would avoid having to make too many costly changes.
Another question is related to the GPS: does anyone know if it works in Europe if I buy the europeen DVD from Nissan?
Thanks
Y
Old Sep 5, 2007 | 06:29 PM
teh_ginger's Avatar
teh_ginger
WTF!? What does Switzerland have against HID's.
Anyway, I'm no 350z owner (so someone can correct me), but I think all you need is the proper halogen bulb (H1, 9006, etc...). It certainly isn't going to require you to upgrade your fuses, as it's not going to sap as much power. But there is the problem of the HID ballast. You might have to do some re-wiring.
Old Sep 5, 2007 | 06:30 PM
rcdash's Avatar
rcdash
The high beams/fogs are halogen. Could you get by just disabling the Xenon during inspection? At least this is true pre-projector units (pre-05?)
Old Sep 5, 2007 | 06:40 PM
Richy350Z's Avatar
Richy350Z
that's gay. f*ck it. be the first one with hids
Old Sep 6, 2007 | 07:53 AM
Wheelman's Avatar
Wheelman
I'm sure if that is your best option that someone here will gladly swap their base headlights for your HIDs.
Old Sep 6, 2007 | 09:11 AM
Zivman's Avatar
Zivman
Originally Posted by JYP
Hey Guys,
Thanks
Y
This stems from euro spec vs us DOT spec. basically the cut-off is different. I would think you would have the same issue with halogen housings as well as long as they are US DOT spec. I would research this further. If it comes down to it, I think you could find a set of E-spec assemblies off a salvage car or find a dealer willing to discount them for you and then you could sell off your existing assemblies to the base model guys looking for oem HID to help offset the cost
Old Sep 6, 2007 | 09:20 AM
phreaktor's Avatar
phreaktor
Design Engineer
1. Change the harnesses, swap in the base model or aftermarket headlights.
2. Send me your HID setup.
3. /THREAD
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
Kilroy.Bukowski
Sep 26, 2015 11:24 AM
