03-05 to 06 Headlights and backwards install notes
Old Sep 6, 2007 | 09:47 PM
UrbanTacticZ's Avatar
UrbanTacticZ
Default 03-05 to 06 Headlights and backwards install notes
Ok, so I am looking for some notes in regards to installing 06 headlights on an 03-05 and also the 03-05 headlights on an 06.
I am going to do a swap with a friend and I want to know what's involved for both of us in order to make the headlights functional. I know when you swap the 06 lights into an 03-05, you need to cut one of the legs (middle one right?) on the blinker bulb so it does not stay lit all the time.
What's involved for the 06 to 03-05 conversion? Will it be a simple plug and play or will there need to be some bulb modifications made as well?
I know this has been addressed numerous times but the search feature on this website is truly useless...I was not able to find any information that I was looking for.
Please help!
Thanks!
Old Sep 6, 2007 | 09:49 PM
mr. sparco's Avatar
mr. sparco
Search. Just swap over the harness on the headlights OR make your own harness like I did.
Old Sep 6, 2007 | 09:56 PM
BhashaZ's Avatar
BhashaZ
Check the second post here: https://my350z.com/forum/exterior-and-interior/298895-backedout-06-bi-xenon-headlights.html
Hopefully that helps (btw, I didn't read your post, just the title, so maybe it doesn't apply)
Old Sep 7, 2007 | 12:10 AM
UrbanTacticZ
Can you or someone please elaborate?
I thought that upgrading to the 06 lights from a 03-05 was a plug and play minus the signal bulbs. If that's the case, why would you need to remake harnesses?
Old Sep 7, 2007 | 12:15 AM
UrbanTacticZ
Originally Posted by BhashaZ
Check the second post here: https://my350z.com/forum/showthread.php?t=298895
Woot thanks dude
Now does anyone know any info about downgrading an 06 to the 03-05 lights? Any modification(s) that need to be done?
Uriyo_
Sep 8, 2021 08:46 AM
