Front Speaker Cover
Old Sep 28, 2007 | 04:14 PM
blinkme323's Avatar
blinkme323
Default Front Speaker Cover
Hey guys, how easy is it to replace the front speaker covers? Do they just pop off? If so, what method do you recommend using?
Thanks
Old Sep 28, 2007 | 04:16 PM
tonester1011's Avatar
tonester1011
CF God
Thanks
u should probably remove the door panel unless u can get your hand in there by taking off the door switch pieces..the speaker covers just pop off
Old Sep 28, 2007 | 04:34 PM
oddjobbb's Avatar
oddjobbb
they break easily so be careful. i would pull the door panel just to be safe.
Old Sep 28, 2007 | 05:08 PM
cheshirecat79's Avatar
cheshirecat79
You can use a very small flathead screwdriver to pop them out, but as others said, you should remove the door panel to get an idea how they fit in there before you try doing this.
Old Oct 3, 2007 | 01:31 PM
Anu2g's Avatar
Anu2g
+1..after u take them off once the first time, its cake, but if u remove them improperly the first time, they break, and will not fit on the same again...
i learned the hard way
Old Oct 4, 2007 | 04:34 AM
Voboy's Avatar
Voboy
you can pop them off okay with a very thin flathead without taking them off the doorpanel. val has done this:
https://my350z.com/forum/showpost.ph...9&postcount=46
Old Oct 4, 2007 | 05:54 AM
Rowlett's Avatar
Rowlett
or you can try this mod not sure if its the same one thats already posted....https://my350z.com/forum/audio-video-and-electronics-diy/240044-write-up-my-solution-to-the-stock-sound-blocking-door-speaker-grills.html
Obadabot
Jun 18, 2023 11:31 PM
3vilbunny
Jul 18, 2017 05:10 PM
