Clear Bra Help
Old Oct 7, 2007 | 07:38 AM
jamaicanc's Avatar
jamaicanc
Default Clear Bra Help
Recently I realized that there was a puncture in my Z clear bra. My brother took the vehicle to a car wash and used a pressure washer that created a bubble that filled with water. The water has since dried, but the bubble is still there. Any suggestions on how to get rid of the bubble and make sure that the clear bra goes back to being flush against the car.
Old Oct 7, 2007 | 07:59 AM
lholmesj's Avatar
lholmesj
I have the Clear bra also. Best suggestions is to go back to where you had the install and let them take care of it. I watched my guy do mine and it is was a 4 hour task that was not at all easy.
Old Oct 7, 2007 | 09:27 AM
Spork's Avatar
Spork
Get it redone, I'm sure it has a warranty.
If not, poke it with a pin and press it flat.
Am I the only one that doesn't use pressure washers on my Z?
Old Oct 7, 2007 | 01:37 PM
fb305's Avatar
fb305
Like silverstone-Z said, poke it with a pin and push it down, then let it bake in the sun for a few hours. I never take my car through a car wash or use a pressure washer on it. Car washes use soap with too much detergent in them and it strips the wax off your car.
Old Oct 8, 2007 | 02:34 AM
jamaicanc's Avatar
jamaicanc
Thanks for the info...there is actually a hole (larger than a pin in size) in the bubble and it still has not gone flat.
Sleeper_Z
Sep 30, 2015 10:25 AM
