Heated Seat Q
Old Nov 22, 2007 | 06:37 PM
Amiricanmade's Avatar
Amiricanmade
Default Heated Seat Q
Did a quick search and could not find the answer. I konw it might be a re-post but if i buy leather heated/power seats on a enthusiast, would i be able to install the power and heat? Thanks
Old Nov 22, 2007 | 09:53 PM
bbs350z's Avatar
bbs350z
i dont beleive so. theres a different harness that is spliced into the main electrical harness. i sold my seats to a member here, and he realized that as well. after pulling off my carpeting, we didnt attempt. the heated seat button is just a different harness which can be switched out. imo, just get leather covers if you want them. the electronic features are too slow anyways (mostly because im an impatient bastard, so impatient i came out 1 month premature ) but to my knowledge, it wont work. he has to make a custom power and ground for it. hope this helps
Old Nov 23, 2007 | 11:56 AM
Amiricanmade
thanks for the input. do you have the embers SN?
Old Nov 23, 2007 | 04:20 PM
tonester1011's Avatar
tonester1011
CF God
the power is very simple to hook up...the heat is a bit harder though, needs relays, switches and is a bit more difficult...i bought a set of heated and powered ones for my car, had them reupholstered and hooked up the power...all i did for the power was tap into some wires under the seats.
Old Nov 23, 2007 | 04:24 PM
SuperBlack350z's Avatar
SuperBlack350z
you won't be able to do the heat. Power you can but make sure you do it properly and not just slice in anything.
Old Nov 24, 2007 | 06:07 AM
tonester1011
CF God
heat is very doable, just takes time like i said...if u get a wiring diagram of the car and the correct relays and switches for the seats it can be done...but it was something i didnt feel like getting into for my car. but def need a wiring diagram of the car for starters.
Old Nov 24, 2007 | 11:06 AM
SuperBlack350z
i bought over 180 dollars worth of the correct relays, switches, harnesses, supplies...all authentic nissan parts and still wouldn't work correctly. Nissan told me that it's not even worth it. Thank God they let me return all of the items.
Old Nov 25, 2007 | 07:19 AM
tonester1011
CF God
WOW...i guess its a good thing i didnt even try it then huh!
Old Dec 21, 2007 | 10:07 PM
Nevaland90's Avatar
Nevaland90
tthis should be in the FAQ or a stickey...or what wires to exactly splice would be amazing.
3vilbunny
Jul 18, 2017 05:10 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
