*need help* rails / brackets?
i'm about to buy sparco torino 2 seats but i'm not sure what hardware i need.
i found this:
http://www.mvpmotorsports.com/Templa...684&SearchYN=N
would that be ok or should i go with something else? any suggestion would be greatly appreciated....thanks
i found this:
I have had Sparco's before, and while I am not trying to bash those seats at all, they in no way compare to Brides or Recaro's as far as comfort and quality.
The rails I had for my sparcos also sat a bit high for my taste. While I am not the tallest person in the world, 5' 9 , I felt as if I was in a minivan/truck.
Right now I am using the Bride Zeta III which are great for me (31 waist), but if you dont think that will fit, the Ergo, Gias, and most Recaro's will fit up to 34-36 comfortably.
The rails the Brides come with are also a bit lower seating. The rails used for the Buckets however have 3 height settings, I use the medium one, for a bit lower seating than stock.
If you are set on getting the Sparcos, you only need the seats and proper rails. I would suggest a harness and cage/harness bar tho as the seatbelt might start rubbing on the bolsters and cause premature wear on the seats.
bump for more help.....i cant afford brides and i really want these seats...i love the way how my stockers sit..what else can i do?...more suggestions please... thanks!!!!
tm9293
North East Marketplace
Oct 29, 2015 02:58 AM
